oil pressure issue #830816 08/14/07 05:49 PM
rodeo157 Offline OP
after runnign a while or while 4 wheeling, my oil pressure guage pegs out past 110. the temp is normal, the oil is good. is this a bad sending unit, or is this normal for rodeos?
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
Re: oil pressure issue [Re: rodeo157] #830817 08/15/07 02:07 AM
rodeorat Offline
Mine too! Cold idle 55psi. After about 3-4 miles pegged at 110. Does drop down some when I come to a stop. Mine has the 3.1 GM V6.
GOD Said It, I Believe It, That Settles It.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5855 MB (Peak: 0.6333 MB) Data Comp: Off Server Time: 2026-11-03 20:13:30 UTC
