Removing upper rod bushing #830824 08/14/07 08:13 PM
DanSweet Offline OP
Hi guys, is there an easy way to remove my rod bushings without the sst? Or maybe I should've had the machine shop do that... I was just going to use a punch the size of the bushing and hammer it out, but its pretty tight and I don't want to damage the rod. Thanks,
Dan
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: Removing upper rod bushing [Re: DanSweet] #830825 08/15/07 02:43 PM
OOP'S Offline
Not really that hard to make your own puller.
Machine screw long enough to go through rod, socket, couple of washers, and a nut.
Put washer that is about the same OD as the bushing on machine screw.
Stick screw and washer through one side of rod.
Stick socket with open side toward the rod, on the other side of the rod.
Place washer and nut on screw.
Tighten nut to center.
Tighten nut holding other end with screwdriver if necessary.
The washer will pull the bushing into the inside of the socket, removeing it from the rod.
I have used this for removing bushings and wrist pins for years.
You can also install the bushings the same way.
The new bushings should be fitted to the wrist pins with a hone.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Removing upper rod bushing [Re: OOP'S] #830826 08/15/07 07:17 PM
DanSweet Offline OP
Thanks! I'll give that a try.
Dan
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5945 MB (Peak: 0.6481 MB) Data Comp: Off Server Time: 2026-06-07 04:25:48 UTC
