subaru #830931 08/15/07 03:41 PM
rvdjr Offline OP
this has nothing to do with a kia, but there isnt a forum for subarus. has anyone every put a lift or installed taller tires on an Outback? i just bought one and it drug bottom on a tall speed bump. i would like to get a few inches more ground clearance (preferably without loosing fuel milage)
Re: subaru [Re: rvdjr] #830932 08/16/07 02:56 AM
DennisThompson Offline
I have never seen a lift for an Outback but I'm sure for enough money someone could make one. The Outback is not the same type of 4WD as the early model Sportage. The Kia has a part time transfer case with a low range gear. Your Subaru is full time with no low range. The Subaru is a great all weather car built to look like a suv and handle like a car. It is not designed off road like you have allready descovered with speed-bumps. If you are not into 4wheeling you have a great reliable vehicle. If you just want to clear speed bumps try to find out the tallest tire you can fit, it might use a little more gas but not much.
Hope I helped a little, Dennis
Re: subaru [Re: DennisThompson] #830933 08/16/07 08:12 AM
O
oul053 Offline
i have seen subaru forresters raised so i dont see y they wouldnt have a kit for an outback do a search for kingsprings they will have some. <img src="/forums/images/graemlins/kewl.gif" alt="" />
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: subaru [Re: oul053] #830934 08/16/07 08:37 AM
Hydra747 Offline
My next vehicle will be the Baha.....AWD!
Has an off road susp.!
Would like to raise the body a couple...
GOOD POST! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Looking at RB body lift-----but susp.---another story? <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: subaru [Re: rvdjr] #830935 08/20/07 06:31 PM
Lou Offline
I would install inflatable shocks
Re: subaru [Re: Lou] #830936 08/20/07 11:21 PM
dirtcrazy Offline
Got torque?
'02 Ford F-350 STD Cab V10 6sp 4x4
12MPG in town and 15-17 on the highway.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-09 22:01:40 UTC
