Help - Strange noise when front tire drives over curb
#830953
08/15/07 04:21 PM
I did a few searchs on this, but counld not find any thing. When one wheel drives over a curb I hear a very loud creaking noise. What do you think ?
San Diego CA
Re: Help - Strange noise when front tire drives over curb
[Re: KarlC]
#830954
08/15/07 04:42 PM
My money is on it needing a good greasing. There are a bunch of zerks under the front end. Brandon can testify to how loud/much my front was squeaking when I hit bumps, and a good greasing silenced it completely. Otherwise, it could be a number of different frond end parts that are worn. I'll let someone qualified suggest further info.
[Re: stony-man]
#830955
08/15/07 04:48 PM
Mine is well-lubed and still has a creaking at full lock on uneven surfaces. Still haven't figured it out. But nothing is broken or severely worn, so I live with it. That said, greasing the front end would be a good place to start <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: hazy_daze]
#830956
08/15/07 04:51 PM
Mine is well-lubed and still has a creaking at full lock on uneven surfaces. Hint, Steering stops.
[Re: OldColt]
#830957
08/15/07 05:01 PM
Ok, that makes sense. Thanks Charlie. Is there any lubrication or hacking needed on those?
[Re: hazy_daze]
#830958
08/15/07 05:42 PM
I but a dab of heavy grease on the stops..quiets them down for a while..
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
[Re: justice]
#830959
08/15/07 07:50 PM
Sweet, thx Justice. I'll try that.
[Re: hazy_daze]
#830960
08/16/07 03:18 AM
Upper ball joints on t-bar cranked rigs makes that noise too. At least, that's what I've been told (by Ray, who isn't a mechanic <img src="/forums/images/graemlins/lol.gif" alt="" />).
KG6VNX
[Re: hazy_daze]
#830961
08/16/07 02:40 PM
There is a turn stop that slides up and down when at full crank and you hit a bump. This has a hard plastic piece that wears out easily. So when at full crank you get this horrendous sweak!!!. I periodically squirt a gob and black silicone adhesive on the bolt and slide point which helps alievate this.
