WVO setup in trooper? #831014 08/16/07 02:18 AM
bellavesus Offline OP
Hey there
i am setting up a WVO system in my trooper and i am busy gathering all the components that i will need. I have noticed some people use a 3 port fuel switch, while others use the 6 port. For the 3 port it seems that they loop the return line(s) back to the feed line, thereby making it unnecessary to have return lines, and only needing a 3 port switch. possible benefits are ease of installation for sure, are there any downfalls anyone can think of for the 3 port switch in comparison to the 6 port?
~also, any users have any good leads for coolant based fuel heaters/filters? i am going to install a "hot fox" pickup tube, but was also wanting something up near the injector pump.Thanks in advance,
86 Turbo Diesel 4dr Trooper 4JB1TC
89 turbo diesel Trooper-RED
Re: WVO setup in trooper? [Re: bellavesus] #831015 08/30/07 12:23 AM
OutfitBoss Offline
check these coolant heated fuel filter http://www.frybrid.com/filters.htm
Filters
By the way, I have a member's 86 Trooper here at my house which is setup to run WVO in a two tank system This one uses two three port switches
Brian Rodgers
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: WVO setup in trooper? [Re: bellavesus] #831016 09/05/07 05:24 PM
svanmatr Offline
found this trooper td on ebay with a rather elaborate set up for wvo. Ask this seller for info maybe.... http://cgi.ebay.com/ebaymotors/ws/e...=&item=140152465830&rd=1
Re: WVO setup in trooper? [Re: svanmatr] #831017 09/13/07 06:41 PM
OutfitBoss Offline
Wow that was an outrageous price he got for that Trooper $6100.00 for any 1986 vehicle is a lot and 4X4 high pops out of gear?
Brian Rodgers
Brian Rodgers
www.outfitnm.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6017 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-17 12:00:35 UTC
