"isolated" rear leaf spring mounts? #831393 08/18/07 04:33 AM
btn Offline OP
On my truck (89 standard cab/bed 22re) I have the wide u-bolts with the clam shell plates that cover the leaf packs where the u-bolts clamp down. Originally there was a rubber liner inside of them. I know lots of models didn't have those...just the u-bolts clamping directly over the leaf pack.
Anyone know what the point of these plates was?
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: "isolated" rear leaf spring mounts? [Re: btn] #831394 08/18/07 04:55 AM
cktoy Offline
probably cut down on noise
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: "isolated" rear leaf spring mounts? [Re: cktoy] #831395 08/18/07 08:16 PM
cktoy Offline
just a guess
oh what a feeling:
84 supra yard art
Re: "isolated" rear leaf spring mounts? [Re: cktoy] #831396 08/18/07 11:35 PM
4Crawler Offline
Yes, that is my guess as well. Basically had a metal clam-sheel around the entire spring pack, lined with rubber to eliminate any metal-metal contact. Even the head of the center pin in the spring pack was encased in rubber where it went into the spring perch as I recall. Worked fine until you added a leaf to the spring pack or installed a thicker spring or tried to use a u-bolt flip kit, where none were designed for that wider spring perch. Have seen folks notch the sides of the perch to let the narrower u-bolts and spring plates be used.
I have a set of the clamps and rubber liners if someone is needed those parts.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6009 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-07-13 21:38:31 UTC
