25mm torsion bars...how much lift?
#831446
08/18/07 09:37 PM
If I replace the torsion bars in my 93 4Runner, how much space can I get between the top of the rim and the fender? BTW I do have manual hubs. Thinking of 33" tires before long.
DON'T MOVE!!!...Lemme get the camera!
Re: 25mm torsion bars...how much lift?
[Re: av8soulfly]
#831447
08/18/07 09:50 PM
[Re: Adam F]
#831448
08/18/07 11:18 PM
how hard do you want the front suspension? ive got a set if you want them...PM if interested.
[Re: Adam F]
#831449
08/22/07 09:23 PM
I have 15" of space between the top of the wheel and the fender now, with stock torsion bars. If I go to 25mm bars, will I be able to crank more than 15" of space? And will the new bars noticably decrease my already limited articulation?
[Re: av8soulfly]
#831450
09/03/07 11:00 AM
J Roll Me Over
You can crank the stock bars for more lift the same as aftermarket bars.
My suggestion? DON'T CRANK THE FREEKING BARS!!!
Get a set of ball joint spacers... 1.5" lift, and you maintain the factory ride.
Did you even read the suspension link posted above? <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6050 MB (Peak: 0.6687 MB) Data Comp: Off Server Time: 2026-10-21 19:17:57 UTCValid HTML 5 and Valid CSS
