front diff
#831599
08/19/07 06:27 PM
i put a third member with 5.29 gears and aussie locker in front end and with hubs locked i can hear the gears when driving,then when shift into 4wd the sound goes away.i had a local shop setup the gears and locker and it all looked alright. any ideas why it does this would be helpful before i pull it all apart,thanks
Re: front diff
[Re: kc85]
#831600
08/19/07 06:44 PM
what kind of gears are they? some gears are noiseier then others. as to why the sound would go away in 4wd im not sure.
87' ext cab toy
Re: front diff
[Re: kc85]
#831601
08/19/07 07:34 PM
they are geniune gear,i know their cheap but its what i could aford. i have used them in two other rearends with with no problems but never in front.
Re: front diff
[Re: kc85]
#831602
08/20/07 12:17 PM
Without the drive engaged aren't you riding on the coast side of the gears?
Sounds like a setup issue to me. Hopefully Zuk will be along shortly. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: front diff
[Re: kc85]
#831603
08/20/07 09:54 PM
i think your right. jacked up truck,locked hubs spin tire foward i can hear the gears, spin it backwards no sound.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6037 MB (Peak: 0.6675 MB) Data Comp: Off Server Time: 2026-11-03 12:22:49 UTCValid HTML 5 and Valid CSS
