Damn Idiot Lights #831774 08/20/07 09:18 PM
bradford_johnson Offline OP
OK, so the "Check Gas Cap" light comes on, and sure enough, the fuel attendant (I live in OR, so we can't do it ourselves, only a certified "expert" is allowed the privilege) did not screw the cap on tight enough. I tightened it and consulted the owners manual, and it says the light should go off after "several" driving cycles. Anybody know how many several is? It's been more than two weeks now, and the light is still shining bright.
2004 TJ Wrangler Sport
Re: Damn Idiot Lights [Re: bradford_johnson] #831775 08/20/07 09:46 PM
BigJim Offline
A driving cycle is a prescribed number of miles.. I'm thinking 20 or more at hiway speeds.. If you are sure the cap was loose just drive it.. Eventually the light will dissapear.
Re: Damn Idiot Lights [Re: bradford_johnson] #831776 08/20/07 11:11 PM
Bigbird79 Offline
Hate to ask the stupid question, are you sure the cap is tight and the gasket is good? The light doesn't measure position of the cap, its either a pressure or vacuum sensor. So there is the off chance if its been on that long, you could still have a problem.
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Damn Idiot Lights [Re: Bigbird79] #831777 08/21/07 12:37 AM
That is what I'm afraid of. I guess I'll have to brave the Jeep Service Department (I hate those guys) and have them check it out. Still under warrenty, so it's just the inconvenience of it all.
Re: Damn Idiot Lights [Re: bradford_johnson] #831778 08/21/07 04:01 AM
ChefMark Offline
Does the 04 models have self diagnostic test by turning the the ignition 3 times like on the 97's and some other years?
Would that trigger code read of potential issue regarding a Check Gas Cap light?
I know it works wonders with the Check ENgine light.
It may be worth a shot. The Dealerships will charge at least 90 just to hook it up.
my 2 pennies
Chef Mark
Life is like a hardcore offroad trail...put it in 4-lo and get over it!!
97 TJ, (R.I.P.4-Cyl) 5.3 Vortec Gen III, NV4500, Ford 8.8 Rear, 30 Frnt, 33" BFG MT, 4.25" Susp, 2"Bdy, OBA, Rk Hrd 4x4 Cage, bunch of other cool stuff.
Re: Damn Idiot Lights [Re: ChefMark] #831779 08/22/07 05:46 AM
Can you be more specific? Just turn the ignition three times witout it cranking over?
Re: Damn Idiot Lights [Re: bradford_johnson] #831780 08/22/07 12:17 PM
sweet97wrangler Offline
It doesn't work with 04's Try your local autoparts store Brad, they should scan your truck and turn your check engine light off for you for free.
A drive cycle is more than just driving twenty miles on the freeway. Its a OEM prescribed number of starts, stops, hard and light accelerations and cruising. Depending on how you drive it could take days or weeks, but the computer is looking for these certain prescriptions to occur before it considers itself in a drive cycle. Only then will it perform the self diagnostic of the fuel tank and cap seal and turn off the light.
97 Wrangler Sport, 31" BFG All Terrain, .30 over 4.0L w/ Comp cam, P&P Head, Banks Header, Throttle body, chip.
Re: Damn Idiot Lights [Re: sweet97wrangler] #831781 08/22/07 05:22 PM
Thanks. I stopped by the local Jiffy Lube here and they erassed the code for me. If it shows up again, I'll take it to the dealer here. Our local Jeep Dealer's Service Department leaves much to be desired and I continue to look for a decent shop locally.
Re: Damn Idiot Lights [Re: bradford_johnson] #831782 08/22/07 05:59 PM
cjensen Offline
I agree, the dealer here in SE WI is at best comprable to a 70 filling station....
C.
<img src="/forums/images/graemlins/nana.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6268 MB (Peak: 0.7140 MB) Data Comp: Off Server Time: 2026-11-15 15:57:27 UTC
