1994 4X4 Toyota Rear End Differential Problems #831807 08/21/07 02:25 AM
JNetTrecker Offline OP
While enjoying a 70mph trip down the tollway on Friday I nearly got thrown through the windshield by my rear end which had locked up. Long story short when I hot it to the shoulder the rear end unlocked and I was able to cripple it to a parking lot where I dropped the rear shaft, locked in my front hubs and drove home. I havenÆt actually taken the housing apart yet but there is ?ö play in and out on the yoke and over ¢ö play when I twist it. Other than this truck runs great.
QuestionÆs:
1. Anyone interested? Make an offer?
2. Where can I buy reasonably priced rear end parts?
3. Do you think I should replace the whole rear end?
4. Why are women so confusing?
Year: 1994
Miles: 218,000
Model: Hilux Ext Cab
Motor: V6 3.0
Suspension: 3ö Lift
Tires: 33ö KumoÆs
Thanks for your help guys.
Josh
If you are not living on the edge, You are taking up too much space.
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: JNetTrecker] #831808 08/21/07 02:33 AM
4Crawler Offline
Get a used 3rd member from a junkyard if you are running something with stock gears:
- http://www.car-part.com/
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: JNetTrecker] #831809 08/21/07 04:24 AM
trcdrunner Offline
QuestionÆs:
[color:"blue"] aaawww keep it its a toy!!!! [/color]
[color:"blue"] Junkyard / Ebay your probably running 4.10 (check for sure..) [/color]
[color:"blue"] Remove locked up diff - give a feel around for any teeth or shards of metal, insert new diff fill with gear oil. (now a good time to replace seals if needed..) [/color]
[color:"blue"] I'm not touching that with a 10' pole <img src="/forums/images/graemlins/ignore.gif" alt="" /> [/color]
Year: 1994
Miles: 218,000
Motor: V6 3.0
Suspension: 3ö Lift
Tires: 33ö KumoÆs
Josh
aka FireNIce
84 Runner 33" Swamper LTB, 4.30's, Spool in Rear, Lock-Right soon in front exo-caged, 4" lift.
TRCD Toys Web Site
TRCD Toys Apperal
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: JNetTrecker] #831810 08/22/07 02:55 AM
cktoy Offline
guy in ky has whole rear end for 150 bucks.no trouble to replace third member either.fix it man thats a good year truck to have I think
<img src="/forums/images/graemlins/ignore.gif" alt="" /> x2 on question #4 I think thats another site .check with opra or something <img src="/forums/images/graemlins/lol.gif" alt="" />
oh what a feeling:
#1 86 xtra cab 22R,EB 261 cam ,Hooker header,2" ex with cherry bomb, Aussie powered
#2 86 sr5 4x4 efi parts truck
#3 87 2wd parts truck
84 supra yard art
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: cktoy] #831811 08/22/07 04:45 AM
dcg9381 Offline
Josh, that's a $50 repair in TX.. basically a stock 4.10 (if you've got 4.10) 3rd.. 2 hours to do it.
22REturbo.net
1988 4Runner
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: dcg9381] #831812 08/23/07 05:24 AM
Any Leads on where to get a 3rd member here close to Dallas? I am ok with a 4cyl pumpkin. I tried to look on Pirate4X4.com but you have to pay $20.00 a year to use the search function and there are like 25,000 post so I could build a truck from the ground up quicker than reading them manually.
I am hoping to stay under $200.00 including shipping.
According to my plate codes I have the following.
8" Rear End
4.556 Gears (If I understand my code "G254" correctly this 1994 V6 5-speed Manual truck came with a 31" tire upgrade which makes it a 4.556 gear ratio)
4 Cyl. (Pinion) (I am ok with a 2 cyl.)
Josh Brown
[per the user agreement for this website, do not post your phone number in public domain. This is for your protection and privacy. Thank you.]
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: JNetTrecker] #831813 08/23/07 05:33 AM
kewlynx Offline
Try www.car-part.com for local junkyards. I haven't seen any 3rd generation trucks up for parts in our for sale section lately. Post up in the parts wanted section to see if you get any leads.
**ubi apis- ibi salus**
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: kewlynx] #831814 08/23/07 02:58 PM
Staceman Offline
This should put you in the ballpark. Usually, shipping costs are very reasonable thru car-part.com
Carrier
Toyota 4Runner Axl, 4X4, 6 Cyl, w/o ABS; 4.56 ratio--B A E071 $150 All Foreign Auto Parts, Inc. USA-TX(San-Antonio) Request_Quote 1-800-833-4941/1-210-623-5000 Request_Insurance_Quote
1989
Carrier
Toyota Truck CHK RATIO 207312 $125 Shipman Auto Parts, Inc. USA-MN(Brainerd) E-mail 1-800-892-4779
Re: 1994 4X4 Toyota Rear End Differential Problems [Re: Staceman] #831815 08/23/07 03:01 PM
Staceman Offline
Heres one with ABS. Just cut the cable if you don't have ABS.
Carrier
Toyota 4Runner OUT READY TO GO IN VEH#1081 #60079 $100 Lowe's Auto Parts, Inc. USA-TN(Knoxville) E-mail 1-865-577-2561
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6320 MB (Peak: 0.7377 MB) Data Comp: Off Server Time: 2026-06-07 05:34:52 UTC
