The Nutter bypass #831834 08/21/07 03:06 AM
SkibumMt20 Offline OP
I have an 87 YJ and am looking into doing the Nutter Bypass. I can identify the Orange and purple wires coming out of the distributor. Coming out of the ignition module on one side, from the module to the plug there is a light green wire, a black wire, a dark green wire and a orange wire. From the plug going into the split loom covering there is a green wire with a white stripe, a green wire with a purple stripe, and a straight green wire. There is also a green wire with a white stripe going into the firewall. I have the Nutter bypass instructions and am confised.
89 YJ DD
87 YJ 350 TBI, SM465, NP241(eh), SOA w/1.5" springs, 35" MTR, D44 (aussi locker)/14bolt (welded) with 4.88's
Re: The Nutter bypass [Re: SkibumMt20] #831835 08/21/07 03:35 AM
BigJim Offline
I never saw one that didn't have a purple and an orange wire coming out of the module.. I always cut between the module and the plug...I ignore the other colored wires.
You might have a CLOSER look at the colors.. Look at the entire length before the plug.. the part you have seen MIGHT be discolored from heat or whatever.
Re: The Nutter bypass [Re: BigJim] #831836 08/21/07 12:49 PM
superdawg Offline
TBI or MPI is the only correct way to disable the OE feedback carb system.
Delete this thread please.
SD
Re: The Nutter bypass [Re: SkibumMt20] #831837 08/22/07 12:15 AM
Would it be as simple as cut the wires at the ignition module and the wires at the distributor and then tie them all together with their corresponding colors?
89 YJ DD
Re: The Nutter bypass [Re: SkibumMt20] #831838 08/22/07 03:17 AM
BigJim Offline
The purple and the orange yes.. the others I just leave alone..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6035 MB (Peak: 0.6677 MB) Data Comp: Off Server Time: 2026-06-09 21:54:18 UTC
