Finally, real 4x4 experts! Help needed... #831877 08/21/07 07:39 AM
Danica Offline OP
I have a 1991 Jeep Wrangler that I recently blew a rod through the engine block, I recently bought a 1991 engine for the jeep, but the engine is automatic. My jeep has a standard engine. I want to make the automatic engine work. the pilot bearing in the standard engine does not fit into the automatic engine because they were not made to be converted. I believe that it is possible. Anyone have any ideas? Plus has anybody ordered from this site ? Probably the best place for OEM Jeep Parts.. OEM Jeep Parts
Re: Finally, real 4x4 experts! Help needed... [Re: Danica] #831878 08/21/07 12:52 PM
sweet97wrangler Offline
Danica it is possible,
I put a 93 AT motor in my MT 97 wrangler and ran into the same problem, the hole in the end of the crankshaft is much to big for the pilot bearing. You have to go to the dealer ( <img src="/forums/images/graemlins/barf.gif" alt="" /> ) and order a sleeve that gets pressed (I used a socket and a hammer to install mine) into the end of the crank, the sleeve then holds the pilot bearing. The sleeve comes with the pilot bearing already installed. I believe it was a $20 part. Your website doesn't have it. You should be able to see the sleeve and pilot bearing in the crank of your original motor, unfortunetly it cannot be removed without destroying it.
97 Wrangler Sport, 31" BFG All Terrain, .30 over 4.0L w/ Comp cam, P&P Head, Banks Header, Throttle body, chip.
Re: Finally, real 4x4 experts! Help needed... [Re: sweet97wrangler] #831879 08/21/07 03:21 PM
BigJim Offline
"unfortunetly it cannot be removed without destroying it."
The ones I take out aren't destroyed.. How do YOU get em out S/W?
Moderated by  4x4Wire, Mudraider
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5913 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-07-17 03:58:40 UTC
