lash adjuster replacement
#831984
08/22/07 03:10 AM
First and foremost I searched for lash adjuster replacement. I didnÆt find much. I have some pretty annoying tapping that gets louder as the engine warms up. When I am at a higher rpm it is not as noticeable. But when I am going slowly off road it bugs the heck out of me. Are they difficult to replace and does anyone think this would help the tap tap tap I hear?
Pat
1990 MonTERROR 183.07 cubic inches of worn out FURY New ALTINATOR And uh... new radiator hoses UPPER AND LOWER, SAGGING COILS, dead SHOCKS Worn 29 x something x something else STREET TIRES GET SOME
Re: lash adjuster replacement
[Re: Baldylocks]
#831985
08/22/07 03:18 AM
if you are going to take them off the heads you can clean them your self I put mine in diesel fuel I read that some where on here. after a few miles they tend to get that way. (dirty and stuck) If you are in the market for some new heads with new adjusters I have some be glad to hook you up <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Baldylocks]
#831986
08/22/07 04:05 AM
Sometimes they get varnished up over time. See if you can find some BG MOA oil additive at any local New Car Dealership. The service writers can tell you. It's usually used to augment services and won't be on display. Change your oil and add it in and leave it in. It's about the best cleaner/oil conditioner around and is the best shot at cleaning the valve followers the easy way. This stuff and their fuel injector cleaner is about the best available on the market. I'm sure you can also get it online. There is some on Ebay.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
[Re: Pete_D]
#831987
08/22/07 03:23 PM
Or it's a slapping piston, and not the HLA's.
Replacement should be pretty easy, but it's as much work as a timing belt replacement (which you should do), and take care in sealing back up, or you'll get an oil leak at the upper/lower cam bearing bosses at the front&back of the engine.
[Re: fasteddy]
#831988
08/24/07 03:18 AM
Oh I HOPE it is not that. Thanks again for your help.
[Re: Baldylocks]
#831989
08/24/07 12:46 PM
I've used transmission fluid in the oil to free up stuck lifters. On a 5 quart system, substitute one quart of dexron into the oil. Change oil and filter in about 1500 miles. Trans fluid is highly detergent and great at cleaning.
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
[Re: toddstidham1]
#831990
08/24/07 01:04 PM
[Re: FrankR]
#831991
08/24/07 02:01 PM
x2 for Rislone. Used it before, worked well.
[Re: FrankR]
#831992
08/24/07 06:06 PM
Same idea as above? Substitute 1 quart rislone for 1 quart motor oil and change oil+filter in 1500 miles? Eric W.
[Re: 89IsMine]
#831993
08/24/07 06:29 PM
You don't have to change the oil at 1500 miles. You can leave the Rislone in there.
