Page 2 of 3 1 2 3
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: kewlynx] #832052 08/30/07 01:47 AM
RichinROA Offline OP
You mean the whole assembly and all? Will do. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I'd hate to plunk down more loot for this problem. I can't complain though...177K+ and never been a big pain at all.
If my wife didn't drive the truck at all, I'd have no problem with letting it by, but since she drives it, its worth the piece of mind.
"Coal and people have been our two biggest exports for a long time, which has definitely shaped how we think of ourselves." Scott Hill, WV native and historian.
99 TacoTRD 177K
Montani Semper Liberi
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: RichinROA] #832053 08/30/07 02:40 AM
kewlynx Offline
Yepper; yer rattle across the RR tracks prompted that suggestion.
**ubi apis- ibi salus**
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: kewlynx] #832054 08/30/07 04:21 AM
All the clips connections look good, and it holds good. I sprayed some electronic cleaner on it. I think the FSM tells specs for the voltmeter. Will try that when I get light tomorrow. <img src="/forums/images/graemlins/kewl.gif" alt="" />
99 TacoTRD 177K
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: RichinROA] #832055 08/31/07 06:04 PM
Got it on last night ($193 for the dang part !!!! <img src="/forums/images/graemlins/barf.gif" alt="" /> <img src="/forums/images/graemlins/barf.gif" alt="" />) and light didn't come back on (drove about 35 miles last night)until this morning. Giving the same sequence for bad speed sensor, harness checked out fine. I'll try clearing the code out tonight. <img src="/forums/images/graemlins/kewl.gif" alt="" />
99 TacoTRD 177K
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: kewlynx] #832056 09/02/07 10:39 PM
john_luttrell Offline
Sorry, Im showing up for this topic late, been very busy in the oil fields lately. As mentioned, just because the 'puter flagged the sensor doesn't gaurantee it. First check all the connectors for loosness, corrosion, trapped moisture. You need to do this inspection on all connectors in the whole system, not just the one flagged by the computer. Find "ALL" of your ground points and disconnect, clean and reconnect them. The system is very sensitive to high resistance to ground. Then double check all the positive connections coming off the positive lead for security and corrosion. Last, but not least, you may of recieved a bad 'NEW" part; check it against the manual for spec's. I've been a mech all my life and you would not believe how many bad new electronic parts I have recieved. Man, I need to get in here more often..........I'll check back in to see what you find; we'll get the problem solved.
Here is a good starting point for troubleshooting the system................
http://www.ncttora.com/fsm/2003/index.html
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: john_luttrell] #832057 09/03/07 05:15 PM
I jumped the pins, and did the brake pedal 8 times in under 3 seconds like the FSM said, and the light hasn't been on for over a day yet, with plenty of driving on pavement and dirt/ tar chip, over some tracks, etc.
Thanks for all y'alls help with this. <img src="/forums/images/graemlins/kewl.gif" alt="" />
99 TacoTRD 177K
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: RichinROA] #832058 09/09/07 08:03 PM
A
Andy_92563 Offline
I've been having the same issues with the abs light. I even cleaned all 4 abs sensors, but no luck. I spent $100 for the diagnostic thru dealership and read "front left speed sensor bad". I bought the part (yep $190) replaced but still have the abs light coming on occasionally!! I did not however jumped the terminals as what stated on the previous post. this has been an on-going problem for me for 3 years now. When abs light is not on when applied the brakes it works, but before the light comes back when applying the brakes, it would grind and sound a big spring coming un-done then the abs light would come back. So far, I only changed the front left speed sensor, I don't want to buy the rest of the 3 if it is not going to work. one thing that the dealsership had advised me is that to replace the entire abs unit ( $900 !! )
If someone could direct me to a site on how to jump the cables etc, it would be a good help. Thanks in advance.
ps. I've emailed/contacted toyota motor sales U.S.A. about this problem, here's the response:
"Thank you for contacting Toyota Motor Sales, U.S.A., Inc.
Your interest in Toyota producsts is appreciated.
We make every effort to manufacture a quality product by researching, testing, and constantly monitoring performance. Consumer opinion and perception also play an active role in our ongoing efforts to lead the automobile industry in quality, innovation, styling, and reliability.
Your feedback is appreciated; it is through communications such as yours that we become aware of our customers expectations and reactions. It also provides us with valuable insight when planning and developing future products and services to increase our customers' satisfaction.
Your comments regarding seeing these options on future versions of our products have been documented at our National Headquarters under file #200604111175 and are available for review by the appropriate departments.
Toyota Customer Experience "
but until today,no one has contacted me about this problem.
-Andy
1999 Tacoma Black Limited V6, 4x4,104K,LEER shell cover, deck plate air box amsoil air/oil filters w/ amsoil fluids, bilsteins shocks front & rear
3" toytec coils & AAL, 4 new TOYO tires (31x10.5x15). selling truck to the right price!!
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: RichinROA] #832059 09/09/07 08:05 PM
A
Andy_92563 Offline
RichinROA, where did you find on how to jump with pins? I would like to try that to see if it works.
-Andy
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: Andy_92563] #832060 09/10/07 02:25 PM
Sorry- I been out all weekend.
If you go to the opening page of the taco tech forums, you'll see a sticky for Online Factory Service Manuals.
fsm sticky
In the first post, you'll see a link for the ebsco host database at bedford library. The fourth post from the bottom has a login for this DB.
Find the year of your truck. When you get to the main page, look along the left side for the 'brakes' section, then expand the 'anit-lock brakes' section. Click on 'inspection' and it'll give you the procedure for clearing codes.
I also used the same sticky to find a Toyota factory service manual and got a diagram of the pins on the connector, and a parts locator. Can't find them exactly now, but it just takes a bit of nosing around in that sticky.
Clearing Codes
Detach the service connector at the actuator.
Use the jumper wire to connect terminals Tc and E1 of the Data Link Connector (DLC1). Turn the ignition ON.
Clear the diagnostic trouble codes stored in the ECU by depressing the brake pedal 8 or more times within 3 seconds.
After the rapid pedal application, the dash warning lamp should display constant flashing, indicating a normal system. If codes are still displayed, make certain the repairs made to the system are correct. Also inspect the brake light switch at the brake pedal for any binding or sticking.
Once the codes are cleared, disconnect the jumper wire. The dash warning lamp should go out.
99 TacoTRD 177K
Re: ABS light...have searched, just a few questions b4 trouble shooting [Re: RichinROA] #832061 09/10/07 11:56 PM
A
Andy_92563 Offline
Thank you for your assistance, I'll try it and will I post afterwards. I sure hope this works, I'm getting tired of looking at the ABS.
-Andy
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6486 MB (Peak: 0.7774 MB) Data Comp: Off Server Time: 2026-05-29 16:11:36 UTC
