An auxiliary transmission fluid cooler?
#832123
08/22/07 11:09 PM
What do you guys recommend? I just got back from 2 weeks in the mountains and my AT Temp light came on a couple of times, I pulled over and let it cool for 5-10 mins then I was good. Anyway now that Im home Im seeing a tranny fluid leak in my driveway. I guess I might have fried the gasket & seals when it got hot. What do you guys recommend I do now and in the future to stop this. (my last tranny fluid change was 17,000 miles ago...last summer)
Thanks, D
91 Monty RS stock sitting on 31's w/polished Alum 16"s 265,000 orig.
Re: An auxiliary transmission fluid cooler?
[Re: Drewz]
#832124
08/22/07 11:51 PM
What do you guys recommend I do now Find out what exactly is leaking and fix it.
[Re: Drewz]
#832125
08/23/07 12:14 AM
Add UV dye to the tranny fluid and see where it's leaking from.
[Re: Drewz]
#832126
08/23/07 12:47 AM
Check your fan clutch after you fix the leak. An aux cooler is a good thing, but can cause more leaks if not installed properly. An aux fan, or wiring your condenser fan with a switch is another, likely more helpful, idea. You don't move as much air across the core of the radiator when wheeling, so an aux fan will help <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Drewz]
#832127
08/23/07 03:13 AM
What do you first is fix those leaks asap. That can cause the tranny to fry up shortly after. I got an extra tranny coolor installed with a puller fan and had it run "in-series" with the transmission cooling system. You wanna make sure the extra tranny cooler is last in the series before it goes back into the tranny. Mine has a puller fan on it and is some-what below the bumper line so I plan on adding a switch to manually shut it off when doing any type of water crossings.
For the future too, I heard Water Wetter works if you pour it in your tranny before you go wheeling, of course after your cool down or before you start the vehicle in the morning. Fix that leak first and go from there. Good luck, Angelo
[Re: Angelo]
#832128
08/23/07 02:22 PM
I heard Water Wetter works if you pour it in your tranny <img src="/forums/images/graemlins/confused.gif" alt="" /> A coolant additive in the tranny? Never heard of that. Anybody else try this?
[Re: hazy_daze]
#832129
08/23/07 03:29 PM
I heard Water Wetter works if you pour it in your tranny <img src="/forums/images/graemlins/confused.gif" alt="" /> A coolant additive in the tranny? Never heard of that. Anybody else try this? oops, sorry, it was late for me <img src="/forums/images/graemlins/lol.gif" alt="" /> I meant if you pour it in your radiator, hope he doesnt sue me <img src="/forums/images/graemlins/ignore.gif" alt="" />
[Re: Angelo]
#832130
08/23/07 03:34 PM
I heard Water Wetter works if you pour it in your tranny <img src="/forums/images/graemlins/confused.gif" alt="" /> A coolant additive in the tranny? Never heard of that. Anybody else try this? oops, sorry, it was late for me <img src="/forums/images/graemlins/lol.gif" alt="" /> I meant if you pour it in your radiator, hope he doesnt sue me <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: sparkem]
#832131
08/24/07 12:54 AM
What do you guys recommend I do now Find out what exactly is leaking and fix it. Thank you Sir... <img src="/forums/images/graemlins/smile.gif" alt="" /> ...It looks like its a rear seal leaking gear oil. It will be an easy/cheap fix. Thanks for e1's input espically the Water Wetter in the Tranny...I dont think I'll be tryin that one anytime soon. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: Drewz]
#832132
08/24/07 03:11 AM
You probably wonÆt believe this but I am a transmission GURU.
This is how to fix it:
1.Buy some black electrical tape. 2.Cut a piece that is exactly the same size as the A/T light. 3.Carefully place it over the A/T light.
With a roll of black tape all of my problems have just simply disappeared.
Kidding bro, good luck with the repair.
1990 MonTERROR 183.07 cubic inches of worn out FURY New ALTINATOR And uh... new radiator hoses UPPER AND LOWER, SAGGING COILS, dead SHOCKS Worn 29 x something x something else STREET TIRES GET SOME
