Page 2 of 3 1 2 3
Re: 2001 Kia Sportage will not start. [Re: Airdale73013] #832356 08/25/07 02:10 AM
kracoman Offline OP
My wife and I went online and found a couple of sites that offered direction to replace the timing belt. It seems somewhat simple to do. "Thanks"!
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832357 08/27/07 03:14 AM
O
oul053 Offline
have u checked the belt? u said that when u 'short' the fuel pump relay it works, have u checked the connnections on the relay to make sure they are not corroded its a common fault.
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: 2001 Kia Sportage will not start. [Re: oul053] #832358 08/27/07 03:51 AM
kracoman Offline OP
Hello,
No haven't had a chance to check anything this weekend do to prior committments, but will check this week sometime after work.
Thanks
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832359 08/27/07 03:54 AM
O
oul053 Offline
ok then well if it cranks over and has compression it wont be the timing belt, it will just free spin noise if its stuffed.
Re: 2001 Kia Sportage will not start. [Re: oul053] #832360 08/28/07 02:05 AM
kracoman Offline OP
Hi oul053,
I've checked the timing and the belt was indeed broke.
I'm planning on replaceing it sometime this week.
Thank you and everyone else for the advice and troubleshooting proceedures. Will keep you posted on the repair.
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832361 08/28/07 08:28 AM
O
oul053 Offline
ok then cool.
Re: 2001 Kia Sportage will not start. [Re: Axe Man] #832362 09/13/07 03:15 AM
kracoman Offline OP
Hi Axeman,
I've replaced my timing belt,spark plugs,fuel pump and both relays. The truck started and ran for 45 minutes or so. I drove it around the block and that's were it died. I think I'm not getting fuel, I'm suppose to change the fuel filter tomorrow evening, but I do not recall hearing the fuel pump running this time,I've check the grounding unit but not sure if I checked correctly or was in the right area. I did sand off the paint on the lid that covers the fuel tank & pump and then replaced the screws. Should I have changed the screws since they were kind of rusty and not getting a good ground,curious, any sugestions?
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832363 09/13/07 08:28 AM
O
oul053 Offline
when u did the relays did u check the connectors on the fuse box cos they corroed and go to *****. if u think its fuel check that. did it do anything funny before it died??
Re: 2001 Kia Sportage will not start. [Re: oul053] #832364 09/13/07 10:35 PM
kracoman Offline OP
When I took the truck for test drive the only thing it did was just shut off, so I coast it to the side and pushed it back home with my Blazer. I'm going to retrace my steps as for checking the fuel system and relay connections. I'll keep you posted.
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832365 09/14/07 03:04 PM
bombardj1 Offline
did you check the belt to see if it broke again ? if so did you replace the tensioner's at the same time the belt was replaced ?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6356 MB (Peak: 0.7425 MB) Data Comp: Off Server Time: 2026-06-07 04:36:19 UTC
