Page 3 of 3 1 2 3
Re: 2001 Kia Sportage will not start. [Re: bombardj1] #832366 09/14/07 10:05 PM
O
oul053 Offline
does it crank over? i had a sportage yesterday at work that didnt start but would crank ,it was auto, and it ended up being a blown brake light fuse, maybe if urs is auto u could check the brake light switch or wiring, just an idea...
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: 2001 Kia Sportage will not start. [Re: bombardj1] #832367 09/15/07 04:54 AM
kracoman Offline OP
I did replace the tensioner the sametime I replaced the belt. I'm not getting fuel, If I connect a jump wire to B+ and fuel pump connector on the dianostic connections the damn pump will run, If I remove it nothing happens. I cleaned the ground wires that connects to the floor panel to the fuel pump, I even cleaned the floor panel and verified the wires were not disconnected on the fuse box with the relays. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: 2001 Kia Sportage will not start. [Re: kracoman] #832368 09/16/07 09:12 AM
hvac1000 Offline
Fuel pump relay?
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.5994 MB (Peak: 0.6689 MB) Data Comp: Off Server Time: 2026-06-22 11:18:42 UTC
