howling in my front end on my 95 sr. #832397 08/25/07 12:10 AM
leftnutt35 Offline OP
Well i posted about whats probably my valve stem seals. now i need to post about a howl in my SR front end. it sounds like it coming from my transmission . its not all the time but when it does it.its like its not wanting to come out of a lower gear. if you can understand what i mean? i am not sure how to explain it. it will go away and be just fine after while and it does not do it all the time. like its stuck in a lower gear then finally it goes up into the higher gear. transmission might need serviced ? don't know when it was done last. i will if needed try to explain this better just not feeling well right now. thanks
95 SR stock but i hope not for long....
Re: howling in my front end on my 95 sr. [Re: leftnutt35] #832398 08/25/07 03:39 PM
toddstidham1 Offline
AH! Open the hood and remove the Wolf that's stuck under there. <img src="/forums/images/graemlins/lol.gif" alt="" />
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: howling in my front end on my 95 sr. [Re: leftnutt35] #832399 08/26/07 12:57 AM
jmdt Offline
Sometimes a differential that is on it's way out will howl. How sure are you that it's coming from the tranny? Noises can be really hard to place correctly from inside a vehicle. If you're sure it's the tranny (not a wolf <img src="/forums/images/graemlins/lol.gif" alt="" />) then try a tranny flush and hope for a cheap fix. That is if you haven't flushed it in a while. How does the tranny fluid look?
Jim
1994 Montero LS
Re: howling in my front end on my 95 sr. [Re: leftnutt35] #832400 08/27/07 04:23 PM
F
frumples Offline
You sure it's a howl and not a wistle? Also does it only sound like it's stuck in low or is the trans not shifting?
Re: howling in my front end on my 95 sr. [Re: frumples] #832401 08/27/07 06:53 PM
i have not driven it in a while but i got a doctor appointment to day and its about 45 minutes away so i plan on taking it and listen to it better. on thing that might be it was my 10 year old son the other day was playing with the switch that picks normal power and hold. i mess with it and made sure it was in normal again. the switch was kind of like stuck in between options when i messed with and i got it back into normal mode. will report back later. thanks
Re: howling in my front end on my 95 sr. [Re: leftnutt35] #832402 08/28/07 12:29 AM
seemed to have done the trick with the switch. no more noise no nothing. sounds great must have been stuck on hold or something seems fine now.
Re: howling in my front end on my 95 sr. [Re: leftnutt35] #832403 08/28/07 12:46 AM
8
89IsMine Offline
Man, I wish all our problems could be solved that easily!
Glad to hear this, Lefty! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Eric W.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6131 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-06-20 19:02:43 UTC
