help my kia want go!!!! #832481 08/25/07 07:56 AM
dburneisen Offline OP
my 2001 kia sportage has been in the shop for 3 weeks now. and my mechanic is baffled..the car goe 20 mph up hill (if your lucky) when peddle is to the floor. we live on a hill and when we back up and put it in drive we dont move. we have replaced the fuel fiter, all four fuel injectors, the mass air sensor, the cat is not clogged, the timing belt is just fine. all tests they run says this car should be running like a locomotive and is not. any suggestions would be great.
thanks
Re: help my kia want go!!!! [Re: dburneisen] #832482 08/25/07 09:54 AM
bombardj1 Offline
did you have a compression test done?
Re: help my kia want go!!!! [Re: bombardj1] #832483 08/25/07 04:57 PM
Iron Offline
5-speed or auto tranny?
Engine coud be fine, you could have an auto tranny issue!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: help my kia want go!!!! [Re: bombardj1] #832484 08/25/07 07:57 PM
yes the test has always come back low vacumm but all the diagnostics on all the parts come back fine, they also noticed that there are brand new coils and other parts on the car. i know that they are going through all the wiring, checked the crank shaft, and the list goes on...i dont know where else to look
Re: help my kia want go!!!! [Re: Iron] #832485 08/25/07 08:08 PM
its a 4x4 automatic they have checked the tranny and said that was working like its supposed along with everything else..i have gone to past forums who seem to have had the same problem and most seem to be a clogged CAT,or issues with timing belt but again they disconnected it and the car ran no better, the timing has been checked countless times.
Re: help my kia want go!!!! [Re: dburneisen] #832486 08/26/07 08:28 PM
Axe Man Offline
Kia Moderator Emeritus
Go back and check the cat converters again. Yes, plural, there are two of them. One is located right on the exhaust manifold. This is the cat that clogs most often. I'll bet if you pull it off the exhaust manifold you'll find the input screen clogged. And you may also find a crack in the exhaust manifold.
The 2nd cat is located directly under the driver's side. It does not clog often but sometimes it breaks down internal and clogs the exhaust.
Your low manifold vacuum readings are a big indicator that something is clogged in the exhaust system. Have your mechanic check it again.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: help my kia want go!!!! [Re: Axe Man] #832487 08/27/07 12:47 AM
thanks Axe i will pass on the info...i will keep an update.
again thanks
Re: help my kia want go!!!! [Re: dburneisen] #832488 08/27/07 03:05 AM
O
oul053 Offline
have u checked the egr pipe that goes from the exhaust manifold round to the egr valve to make sure thats not blocked?
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: help my kia want go!!!! [Re: oul053] #832489 08/27/07 11:52 AM
Axe Man Offline
The 2001 engine does not have an EGR.
Re: help my kia want go!!!! [Re: Axe Man] #832490 08/28/07 01:18 AM
Cen_Tex_KIA Offline
I just want to tack a quick question on at the end of this. It sounds like the primary cat is clogged. Did I once read from someone here that you can take the primary off, replace it with a 3" header flange and splice the o2 wires on the secondary cat sensor to fool the computer?
I hate cats.......more of a dog person! <img src="/forums/images/graemlins/shiner.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6375 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-06-20 19:00:13 UTC
