86 Gen I Montero help! #832792 08/28/07 03:35 AM
Boostcreepr Offline OP
Well i just picked up this pretty decent montero for 400 bucks. Its an 86 5spd has aisin hubs and it has a prblem with flooding itself and running rough.if u disconnect the fuel line from the carb u can get it to start and if u squirt gas into it it will stay running but when u hook the gas back in it floods out. These carbs are crazy looking any help?
Re: 86 Gen I Montero help! [Re: Boostcreepr] #832793 08/28/07 03:48 AM
LRJ4x4 Offline
Welcome !
21 year old carb...www.fcproducts.com. The carb is easy to replace IF you mark all the vac lines and take some digital shots.
Your other option if you don't have emission testing is the Weber Carb.
Make sure you use the search function, as there are a lot of great posts on the carb issue.
Re: 86 Gen I Montero help! [Re: LRJ4x4] #832794 08/28/07 03:52 AM
that carb scares me!! lol i was told its a 3 peice carb.. which sucks too <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: 86 Gen I Montero help! [Re: Boostcreepr] #832795 08/28/07 06:34 AM
LRJ4x4 Offline
After you read chapter 14 of the factory manual a few times you will feel better <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 86 Gen I Montero help! [Re: LRJ4x4] #832796 08/28/07 05:52 PM
CapnCrunch Offline
Just make sure that if you R&R the carb (regardless of what you replace it with) that you ensure the mating surfaces of the carb and the intake manifold are pristinely cleaned of all the old gasket material and smooth. Any leaks there will translate to more problems afterward.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 86 Gen I Montero help! [Re: CapnCrunch] #832797 08/28/07 07:07 PM
torquemonster Offline
if you do not have any emissions testing I would seriously consider buying a weber. it makes your engine from having 1,000,000 vacuum lines into only 1. and its so simple to install. tuning them properly takes some time but once its set right you will love it!
Re: 86 Gen I Montero help! [Re: torquemonster] #832798 08/30/07 04:31 AM
i do have emissions and i seen the webber swaps are like 300 bucks! I only have a haynes manual so i dunno if thats the shop manual or what. smile Ive just been staring at the carb trying to fix it physcoligically <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 86 Gen I Montero help! [Re: Boostcreepr] #832799 08/30/07 04:39 AM
CapnCrunch Offline
87 and 89 Factory Service Manuals
If you have to pass emissions, your best bet is to stick with the Mikuni carb. Word is, the Weber won't pass.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 86 Gen I Montero help! [Re: CapnCrunch] #832800 08/30/07 04:40 AM
CapnCrunch Offline
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 86 Gen I Montero help! [Re: CapnCrunch] #832801 08/31/07 03:52 PM
will the 87-89 manual work for my 86? Also i heard that a 1986 - 1993 B2600 and Mighty Max carb would fit my motor is there any truth to this?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6393 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-20 17:35:19 UTC
