Page 1 of 3 1 2 3
over heating like crazy #832992 08/29/07 12:23 AM
DC Offline OP
After this trip. It's been over heating like crazy. During tghe trip it boiled over a few times on the trail and then it got really hot driving home too. Took it real easy doing it also. So you gear heads out there.. Where should I start..
DC
97Sport A/T 33's
locked front & rear 4.90
5" IFS Lift
Re: over heating like crazy [Re: DC] #832993 08/29/07 12:27 AM
CapnCrunch Offline
This thread is for a 2.6, but a lot of it should still basically apply.
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: over heating like crazy [Re: CapnCrunch] #832994 08/29/07 12:41 AM
DC Offline OP
thanks..
It has a brand radiator from the crash. But i'll check all the easy stuff. Thermosatat, clutch etc. I'll let you know.
DC
97Sport A/T 33's
5" IFS Lift
Re: over heating like crazy [Re: DC] #832995 08/29/07 06:02 AM
52degrees Offline
What kind of coolant are you using? This is important.
KG6VNX
Re: over heating like crazy [Re: 52degrees] #832996 08/29/07 07:18 AM
DC Offline OP
Not sure. It was replaced at the shop when they put in the new radiator. It's green. <img src="/forums/images/graemlins/smile.gif" alt="" />. Right now it's deluted with some water now with me refilling it. It was having heating issues before the accident.The gauge would go barely above center when it boils over. It sits at center when running. I remember though it used to sit at 1/4 on the gauge all the time before. Not sure when things changed or what. I'll check the parts tomorrow.
DC
97Sport A/T 33's
5" IFS Lift
Re: over heating like crazy [Re: DC] #832997 08/29/07 01:49 PM
52degrees Offline
OK. Green is good.
The orange stuff transfers heat better, but plugs stuff up if you allow it to overheat or run low. Probably not what's happening here. I'll go back to my corner.
KG6VNX
Re: over heating like crazy [Re: 52degrees] #832998 08/29/07 09:23 PM
monte Offline
If it does it only at HWY speeds or 4x4'ing only, then your lift or those HUGE tires are probably putting a massive load on that auto-tranny.... transfering the heat to the rad..
If not, look at the water pump, etc... but I had to go to a 4row custom rad setup with the turbo with 33's just to "beat the heat" here in SoCal... after that..
Never looked back <img src="/forums/images/graemlins/kewl.gif" alt="" />
Jason
Re: over heating like crazy [Re: monte] #832999 08/29/07 10:24 PM
CapnCrunch Offline
If that's the case, maybe you should consider some of these. I put a set on my '88 and even on the 100+ days my temp guage generally reads like the engine just barely got warmed up on a cool day. The needle gets only about 1-2 needle-widths into the big, wide "normal" range. I'm also running a 180-degree t-stat so that it tends to run cooler. Gives me more time to react to an overheat if I have one. If it ever pokes up even midway through the "normal" range then I'd be watching it like a hawk. I haven't yet had the opportunity to see how they affect the engine in the dead of winter, but if they don't allow the engine to warm up adequately all I have to do is just block them off under the hood. Easy-peasey. A four-row rad might not be a bad idea either.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: over heating like crazy [Re: DC] #833000 08/29/07 11:32 PM
LRJ4x4 Offline
Did you remove your air shroud when you did the body lift?
Re: over heating like crazy [Re: LRJ4x4] #833001 08/30/07 12:48 AM
CapnCrunch Offline
I'm guessing you're asking DC, but yeah, I removed the lower-half when I did my body lift. Hasn't been on in over two years and I've not seen any adverse effects, although, I know that can be an issue for some rigs.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6424 MB (Peak: 0.7677 MB) Data Comp: Off Server Time: 2026-11-03 12:23:04 UTC
