Re: Starting problems [Re: mag00] #833136 09/02/07 01:08 PM
hazy_daze Offline
Checked it already, it ain't the wire to the starter. Did my oil pan gasket yesterday. You have to remove the starter. Wire was good, had good connection. Gotta get it to act up more often so I can check it. Everything leads to the switch though.
Re: Starting problems [Re: Grandpa Bill] #833137 09/03/07 12:20 AM
Grandpa Bill Offline OP
Same here. When I replaced the starter a couple of months ago I went through all of the wiring to the starter. It's all good, as far as I can tell, good, clean connections, no broken/frayed wires, etc. I had been thinking that it could be the ignition switch. I'm thinking that I'll go ahead and replace it. It doesn' seem that hard. It may have to wait until next month, though. Granny and I have a little vacation planned. Were going to take a cruise to Alaska <img src="/forums/images/graemlins/kewl.gif" alt="" /> ... So ... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Bill Mattson, Certified Old Guy
Monty-less (right now)
Laura Mattson, Certifiable
Get in, sit down, BUCKLE UP, shut up and HANG ON!!!
Re: Starting problems [Re: Grandpa Bill] #833138 09/03/07 01:15 AM
hazy_daze Offline
Ya'll have fun, now, hear. Be safe. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Starting problems [Re: Grandpa Bill] #833139 09/03/07 01:25 AM
v0d Offline
I have that problem with mine. I have to tap the shifter back a bit and then it will turn over. Some times when it won't turn over, I have to shift it in and out of park to reverse and back a few times.
Darth Montero - 1991 LS, with 31" Geolanders on black steel. 172k miles.
http://www.cardomain.com/ride/2939365
Re: Starting problems [Re: v0d] #833140 09/03/07 01:26 AM
hazy_daze Offline
Then your's is the switch in the shifter. Take it out and clean or replace it.
Re: Starting problems [Re: Grandpa Bill] #833141 09/03/07 07:26 PM
Mystery solved!!!
Started playing with the shifter and lo and behold ... neutral safety switch. I'll pull it out, clean it up and I bet it works just like it should. Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Starting problems [Re: Grandpa Bill] #833142 09/03/07 07:43 PM
hazy_daze Offline
Way to go, Grandpa <img src="/forums/images/graemlins/kewl.gif" alt="" />
Have fun on your cruise <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6293 MB (Peak: 0.7203 MB) Data Comp: Off Server Time: 2026-11-19 23:55:33 UTC
