tadem axles on a ford ranger #833143 08/29/07 08:19 PM
I
I_just_dont_know Offline OP
I was just curious I havent figured out the engine replacement or anything I just wanted to get a genaral Idea
about how to link the 2 diffirentials [color:"black"] [/color]
Re: tadem axles on a ford ranger [Re: I_just_dont_know] #833144 09/05/07 06:01 PM
milehighcowboy Offline
take a tandem axle setup out of another pickup and throw it under the ranger may have to shorten things and have some stuff fab'ed though
Re: tadem axles on a ford ranger [Re: milehighcowboy] #833145 09/08/07 03:10 PM
I
Could you tell some of the other models that have a tadem axle I know of the dodge t-rex but every thing else is way to big for the frame that I know of There was a setup using a transfer case and a chain but I dont think that would hold up very. anymore suggestions would be greatly appreciated.
Re: tadem axles on a ford ranger [Re: I_just_dont_know] #833146 09/11/07 01:17 AM
Q
quacker Offline
If you have enough room for it use an old ford single speed transfercase turned around backwards behind your other case. You will have to mate the cases somehow and install a yolk where the old input used to be but that would give you 2 outputs then 1 for each rearend. use rear axles with offset diffs and a driveshaft with a carrier bearing for the rear most axle to go over the center axle. Sounds like a lot of work huh. You could use rockwell axles out of a larger truck they have flanges for just want you want to do. that is if you are going big. GOOD LUCK smile
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6008 MB (Peak: 0.6556 MB) Data Comp: Off Server Time: 2026-07-16 03:25:12 UTC
