A/C belt install #833246 08/30/07 06:36 AM
dirtaddictionslv Offline OP
hey guys long time no talk i just had a quick Q, im tryin to do the belt on my sportage and i cant figure out how to get the belt off does someone know how to do this?? i do this stuff all day long at work and cant figure out this darn kia... kinda sad... <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: A/C belt install [Re: dirtaddictionslv] #833247 08/30/07 06:59 AM
bombardj1 Offline
www.kiatechinfo.com hope this helps
1. Chock wheels.
2. Remove the four engine undercover mounting bolts and the engine undercover.
3. Loosen the tensioner pulley lock nut.
4. Turn the tensioner adjusting bolt counterclockwise to loosen the drive belt.
5. Remove the drive belt.
INSTALLATION
1. Install the drive belt on the pulleys.
2. Turn the tensioner adjusting bolt clockwise to tighten the drive belt.
Specified deflection : 0.35 inch (9.0mm) at 22 lb (98 N) of pressure
3. Tighten the tensioner pulley lock nut.
Tighten lock nut to 24 lb-ft (32 NÀm).
4. Install the bottom plate and the four mounting bolts.
5. Remove wheel chocks.
Re: A/C belt install [Re: dirtaddictionslv] #833248 05/31/08 11:08 PM
P
patman Offline
BTW... My 2000 Sporty A/C belt just broke and it's gotten hot enough here and I gotta fix it real soon.
I found it strange to see that tensioner pulley with only one side on it. Is mine faulty or is it just supposed to only have one side open (not like the usual V-belt idler pulley I've seen in the past.
I'm about to give it a try an I hope I don't need any parts other than the belt..
Any comments are welcome. Thanks
Pat
Re: A/C belt install [Re: patman] #833249 06/04/08 09:25 PM
logansportage Offline
The tensioner pulley should be a single v-belt type tensioner just like on an old school alternator. If one side is missing this is what probably took out your belt.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6000 MB (Peak: 0.6566 MB) Data Comp: Off Server Time: 2026-06-24 07:21:54 UTC
