'87 yj windshield wiper operation #833339 08/31/07 03:33 PM
bhartwell59 Offline OP
my yj windshield wipers don't appear to be running correctly. sometimes they work sometimes they don't.
i don't think it's the wiper/turn signal stalk or the wiper motor... is there a module or something that i can replace (parts are getting harder to find for this 20 yr) and change easily?
thanks
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: '87 yj windshield wiper operation [Re: bhartwell59] #833340 09/01/07 06:11 PM
playinmud Offline
id find out how many volts are supose to be going to the motor at each speed and then pull the plug off of the motor and test it with a voltmeter, i had the same problem you described on my 97, it turned out to be the motor
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: '87 yj windshield wiper operation [Re: bhartwell59] #833341 09/02/07 07:03 AM
the_other_guy Offline
Incase you are interested, I have a wiper motor, and the Intermitten wiper module from a yj that I am parting out. If you find out that either of those 2 things is the cause of the problem, i could hook you up for cheap.
Glad to be of help to you. <img src="/forums/images/graemlins/smile.gif" alt="" />
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: '87 yj windshield wiper operation [Re: the_other_guy] #833342 09/04/07 04:44 PM
let me see what the issue is and i'll get back to you on the motor or module.
thanks
Re: '87 yj windshield wiper operation [Re: bhartwell59] #833343 10/03/07 07:08 PM
ok, well i replaced the wiper motor (no big deal it was running slow anyway) and still have an issue. so the next idea is to try replacing the intermittent switch... which is to the left of the steering column under the dash
but before i do that, what exactly i'm i going to get myself into? is it as difficult as the haynes manual makes it appear?
thanks
Re: '87 yj windshield wiper operation [Re: bhartwell59] #833344 10/05/07 02:39 AM
It shouldnt be hard at all. on mine it was velcroed up under the dash (i couldnt give you EXACT descriptions, because i no longer have the jeep, or the dash.) Im unsure if the dash will need to be removed to swap it tho. It should be easy enough to do without removing the dash i think. It is just a small black plastic box where wires plug into each end. I still have one from the jeep I parted out if you are interested.
thanks
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6104 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-11-02 12:27:00 UTC
