Engine won't line up with mounts #833391 08/31/07 09:59 PM
DanSweet Offline OP
Hi guys, putting my rebuilt 22re back in today and I have the engine bolted up to the tranny, but for some reason I cant get the engine mounts to line up. The mounts on the engine appear to be above the bolts in the engine bay. I've pried and twisted the engine to try to get them to line up, but no dice. Has this ever happened to anyone before? I guess I don't understand how this could happen... Perhaps the engine rested on the mounts and bent them downwards, causing them to not line up? Any tips to help me get the mounts to finally line up? Thanks,
Dan
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: Engine won't line up with mounts [Re: DanSweet] #833392 08/31/07 10:17 PM
4Crawler Offline
Some tips on the web page below:
http://www.4crawler.com/4x4/ForSale/MotorMount.shtml#MotorMountInstallation
Might be the engine/tranny has shifted forward or back when the old one was pulled. With the angle on the motor mounts, it can appear the holes are off one way when they are actually off in another axis.
Re: Engine won't line up with mounts [Re: 4Crawler] #833393 09/01/07 04:25 AM
DanSweet Offline OP
Ok, I finally got it. Had to get the 6 ft pry bar to push the engine to the right while prying with my other hand on the motor mount.... I have found putting an engine in on an unleveled gravel driveway is something I never hope to experience again...
Dan
Re: Engine won't line up with mounts [Re: DanSweet] #833394 09/01/07 04:31 AM
4Crawler Offline
Yep, they can be tricky to get lined up with the motor mounts. I had to winch mine forward with a come-a-long and use a long screwdriver to lever the mounts over to get a bolt started. I found that was mainly due to the stock t-case crossmember being located too far back, maybe it was bent. But when I put in the Front Range crossmember with the engine in the proper location, the motor mount bolts just drop into the holes now.
Re: Engine won't line up with mounts [Re: 4Crawler] #833395 09/02/07 06:24 PM
yodta Offline
I've found that attaching both halves of the mounts to the engine and then easing it onto the frame works best for lining this stuff up.
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6080 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-06-20 18:04:31 UTC
