Tranny fluid question
#833485
09/01/07 04:13 AM
I searched and didnÆt find much on this. (Maybe I donÆt know how to search real good).
I am changing all of the fluids in my 90 Gen I Montero. The last thing is my auto trans fluid. The Haynes repair manual states that if the tranny has a drain plug it does not have a filter. So before I remove all of the things required to replace the gasket and filter, does my tranny even have a filter?
Also I found that Castrol makes a ATF that complies with Diamond-SP II, SP III CASTROL Import Multi-Vehicle ATF
Pat
1990 MonTERROR 183.07 cubic inches of worn out FURY New ALTINATOR And uh... new radiator hoses UPPER AND LOWER, SAGGING COILS, dead SHOCKS Worn 29 x something x something else STREET TIRES GET SOME
Re: Tranny fluid question
[Re: Baldylocks]
#833486
09/01/07 04:35 AM
There is a metal mesh filter inside of the pan bolted on the bottom with 8mm head bolts. If you just pull the bolt, you wont drain all of the fluid.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5871 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-06-07 03:06:31 UTCValid HTML 5 and Valid CSS
