91 6g72 isc questions #833543 09/02/07 02:08 AM
G
gsitts Offline OP
I saw some posts recently reguarding the old ISC vs the isc on my montero. I occasionally have the idle bounce and am Wondering about sources for the new version of the isc.
Thanks
Gordon
Re: 91 6g72 isc questions [Re: gsitts] #833544 09/02/07 02:13 AM
hazy_daze Offline
web page This is where a few of the guys on here have gotten them. Way cheaper than the stealer, but still a factory part. Welcome to the wire <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 91 6g72 isc questions [Re: hazy_daze] #833545 09/02/07 04:54 AM
DirtDriver Offline
My idle is rock solid, but I'm wondering if I should replace my 18 year old ISC anyway after reading this FAQ on DSMISC's web page.
"2. Why should I replace my ISC, besides improving the idle?
There is a far more important reason. If your ISC has shorted coils, it will eventually damage your ECU. Shorted coils will fry the drivers in the ECU; it doesn't take a fully shorted ISC to exceed the current specs on the M5269L drivers Mitsubishi used. They are only rated for 2A 10ms 10% duty cycle pulses max. A closed short (meaning low resistance) ISC coil will easy cause it's corresponding ECU driver to load ("sink") many more times than it normally would; eventually the driver exceeds its rated duty cycle, heats up and shorts. As resistance goes down, current flow increases. The old ISC coils are supposed to test at 28-33 ohms. On those, anything below 14 ohms or above 50 (indicating leaning toward an open coil) would be a problem.
Once an ECU driver goes as a result of shorted coil, several ECU IC circuits will be next in line to be damaged. Why risk your $375 socketed ECU by running with a bad ISC?
3. My ISC tests ok, but I know it's not working. What gives?
Sometimes, the ohms reading can be in spec but the ISC is still bad. Testing with a 6V battery is a better test (tests the ISC motor), but even then you can't be 100% sure. It could be a mechanical plunger problem as opposed to an electrical coil problem, see below #8. Or, your ISC O-ring could be missing, or leaking."
Makes sense to me, but maybe they're just trying to sell ISC's. $131 bucks might make me sleep better, but it'll also buy a lot of cigars.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: 91 6g72 isc questions [Re: gsitts] #833546 09/02/07 05:18 AM
KrzyDav Offline
I replaced the ICS on my 89 V6 around '00 and recieved one from the dealer with an all plastic body. Is this the improved one???
dave h.
Re: 91 6g72 isc questions [Re: gsitts] #833547 09/02/07 01:43 PM
G
gsitts Offline OP
Thanks for the quick answer.... I'll probably order one today. I really believe in better safe than sorry.
Re: 91 6g72 isc questions [Re: KrzyDav] #833548 09/03/07 01:54 AM
G
generation_one Offline
I dont know. The new one is black not tan from what I have read here. I'm sure there is more to it in than that though...
I would like to know if the part number for the '89 montero (auto/3.0) is the same as some other vehicles. I think the number is md614283. My question is would a Galant or minivan use the the same number? Would it be a different part number for the exact same part? I am ignorant of the part number scheme.
Where would I look in the bone yard to find the same part ?
I would like to find an extra.
I thought the new ones were like 70 dollars not 150.
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: 91 6g72 isc questions [Re: generation_one] #833549 09/03/07 04:48 AM
DirtDriver Offline
CAPS lists md614283 as the PN for the idle air control valve. From the illustration, it's the lower part of the throttle body. Def not the ISC.
Re: 91 6g72 isc questions [Re: DirtDriver] #833550 09/03/07 06:27 AM
G
md 614282 --ISC servo.
might be still be wrong, I wrote down in my notes
about 200k miles
Re: 91 6g72 isc questions [Re: generation_one] #833551 09/03/07 12:32 PM
Y
yankneck696 Offline
I know that the coils from the newer vehicles will work, but the plunger may differ. I have 2 spare coils. I THINK the 89 has a difference in plunger legnth, as neither unit worked, but the coils do.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: 91 6g72 isc questions [Re: generation_one] #833552 09/03/07 08:07 PM
DirtDriver Offline
That's the one mate. It was the original PN in effect from 5/88 to 5/89. The next model year it changed to MD614380. CAPS lists PN MD628053 as the replacement for both; $285.79 from the stealer.
MD628053 is listed in CAPS as the replacement part for the Gen2 from 92-94, then it goes to MD628059 for 95-00.
DSMISC's web site is inconsistent. In one place it says they have ISC's for 88-96 Pajero/Montero's, but on the ordering page it only lists Montero 94-01, which seems to correspond to the MD628059. But they also say they can get almost any Mitsu ISC if contacted at [email]sales@dsmisc.com.[/email]
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6348 MB (Peak: 0.7436 MB) Data Comp: Off Server Time: 2026-11-02 21:47:22 UTC
