New Battery terminal connector, now NO cold idle #833790 09/03/07 05:56 PM
O
ONEOFAKIND Offline OP
I replaced my positive terminal conector on the battery and now the engine will not idle while cold at all? I do have it ideling right now (after warming it up)and the strange thing is its smoother than it has ever been.
Can anyone help?
Re: New Battery terminal connector, now NO cold idle [Re: ONEOFAKIND] #833791 09/03/07 10:47 PM
mlclark Offline
Isuzu Moderator
And you are driving a (blank) of (blank) year with a (blank) engine...
Michael
Re: New Battery terminal connector, now NO cold idle [Re: mlclark] #833792 09/04/07 01:41 AM
O
woops <img src="/forums/images/graemlins/scared.gif" alt="" /> what happend to my signature? Must have unchecked the signature box sorry about that.
90 trooper LS
V6 2.8
5 spd
90 Trooper LS
5 Spd
V6 2.8L
Re: New Battery terminal connector, now NO cold idle [Re: ONEOFAKIND] #833793 09/04/07 02:52 AM
lttlbddy Offline
I have the signatures turned off, so I still don't know what kind of vehicle you have.
Re: New Battery terminal connector, now NO cold idle [Re: lttlbddy] #833794 09/04/07 03:19 AM
Jim_Paget Offline
It sounds as though you have a vacuum leak. I am going to make a stab in the dark and guess that it is the line that runs down to the air pump. It is pretty easy to displace and it is the only vacuum line close to the battery.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: New Battery terminal connector, now NO cold idle [Re: Jim_Paget] #833795 09/04/07 04:14 AM
O
Thanks for the response Jim.
I got it. It was in fact a vacuum leak but it was the line coming off of the TB in the back by the firewall. How it came off? Probably when I screamed because I was so pissed off trying to solve the electrical issue.
Thanks again.
90 Trooper LS
5 Spd
V6 2.8L
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6102 MB (Peak: 0.6800 MB) Data Comp: Off Server Time: 2026-06-21 03:14:02 UTC
