could wheel spacers affect flat towing
#833909
09/04/07 01:41 AM
iv always flat towed my yj with a tow bar the other day i went to tow it it wouldnt turn with my truck the only thing i changed was i installed wheel spacers could that affect it or is it somthing else <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: could wheel spacers affect flat towing
[Re: cbrazor]
#833910
09/04/07 02:12 AM
Ok so you DID HAVE the steering wheel unlocked...right? The spacers shouldn't change the towability of the jeep. I have seen too much caster cause the front wheels of the towed jeep to slide and not want to follow the tow vehicle. I like my vehicles to have a minimum of caster anyway so it has never been a problem for me. Also if you have a front locker I doubt it would turn at all when towed. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#833911
09/04/07 02:46 AM
ok first yes the wheel was un locked i do have a locker but i disengagsd it jacked it to cheak it each wheel turns indepently
[Re: BigJim]
#833912
09/04/07 02:54 AM
how do i cheak caster it drives fine no wear on tires and why would caster change
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6023 MB (Peak: 0.6578 MB) Data Comp: Off Server Time: 2026-10-22 07:39:29 UTCValid HTML 5 and Valid CSS
