Electrical? #833967 09/04/07 11:09 AM
DBL_DTY97TJ Offline OP
2001 XJ. Kids were playing in it for about an hour last night, using radio, headlights, etc. Engine not on. When it was turned on next it cranked fine, then died. Cranked again fine, died afer two blocks. Did this two more times. Now seems to be running fine, like it never happened. Alternator? Although I would think if the alt. was going south it would run off the battery till the battery died.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Electrical? [Re: DBL_DTY97TJ] #833968 09/04/07 01:38 PM
BobRowe Offline
Were the kids only playing in the passenger compartment, or did they have access to the engine compartment?
Re: Electrical? [Re: BobRowe] #833969 09/04/07 01:46 PM
They were in the passenger compartment. They have no interest in what's under the hood. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Electrical? [Re: DBL_DTY97TJ] #833970 09/17/07 04:22 PM
bump. It's doing it again...this time when the radio had been left on for maybe 10-15 min. with the engine off. That shouldn't have taken much juice...then it cranked fine and died, cranked again, drove a bit, and died, then again and stayed running. I really don't get it. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Electrical? [Re: DBL_DTY97TJ] #833971 09/17/07 04:34 PM
Brown81CJ5 Offline
Dang gremlins!!
Sounds like maybe a loose connection somewhere. Have you checked your wiring at all? Not sure which wires should be checked, but thats what the prob sounds like to me.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Electrical? [Re: Brown81CJ5] #833972 09/17/07 06:11 PM
Everything obvious looked pretty good. It's the timimg of the thing that get's me...then restarts fine and after a few restarts runs great.
Re: Electrical? [Re: DBL_DTY97TJ] #833973 09/18/07 03:21 AM
Jeepdoc4x4 Offline
what about the key being on and the electric fuel pump running and perhaps due to moving no fuel getting hot?
If it ain't a Jeep why would you drive it??????
Re: Electrical? [Re: Jeepdoc4x4] #833974 09/18/07 02:51 PM
4x4Wire Offline
Have you checked the battery??
I have seen some real strange problems cured by replacing the battery......
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Electrical? [Re: 4x4Wire] #833975 09/18/07 10:33 PM
Actually I haven't. Cleaned contacts - not that they needed it. But the battery had enough juice to crank it with no problem even when it kept dying after starting and running. Maybe I'll have the GF run it by Autozone tomorrow. I've seen dying bats have strange effects too...
Re: Electrical? [Re: 4x4Wire] #833976 09/19/07 07:15 PM
Alternator....going....going....gone. A couple of Ben Franklins to follow... <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6337 MB (Peak: 0.7398 MB) Data Comp: Off Server Time: 2026-10-24 08:17:51 UTC
