Side step removal #834047 09/04/07 07:19 PM
carlover626 Offline OP
Hi there everyone...I am so happy, I got to take the Monte out on Argentine Pass here in CO over the weekend and do some wheeling!
I did have one gripe that was pretty annoying...the bang from these steps laying down on some of the rocks <img src="/forums/images/graemlins/zombie.gif" alt="" /> lol!!
Is there anything special I need to consider when I take these SOB's off? I am thinking of just leaving them off for now...
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
2002 Montero Sport 3.0L LS AWD, 130K - Stock
Re: Side step removal [Re: carlover626] #834048 09/04/07 07:41 PM
stony-man Offline
You can probably use the MontyMcV method...just hang your truck off a biga$$ rock and peel them off. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
They should just be bolted on...they are on the GenIIs.
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Side step removal [Re: carlover626] #834049 09/04/07 07:52 PM
Scottie2113 Offline
just some wrenches sockets ratchets and maybe an extension or two, basic tools and basic wrenching skills
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Side step removal [Re: carlover626] #834050 09/04/07 07:56 PM
Mad_Scientist Offline
Just make sure they don't fall on your head when you take the last nut off <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Scottie has got you covered. Easy job <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Side step removal [Re: Mad_Scientist] #834051 09/04/07 08:29 PM
Thanks guys, I was concerned I would miss something. I'll be sure to watch out before they fall on my head! <img src="/forums/images/graemlins/notooth.gif" alt="" />
Do I need to cover the holes that it is bolted up to, in case of rust or anything to that extent?
Re: Side step removal [Re: carlover626] #834052 09/04/07 08:38 PM
No 'cause they sit on threaded studs under the body. You will just need to remove the nuts. The threaded stubs will stay on the truck so no holes to fill <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Side step removal [Re: Mad_Scientist] #834053 09/05/07 01:15 AM
jfarsang Offline
14mm I think for the nuts
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: Side step removal [Re: carlover626] #834054 09/05/07 05:11 AM
DirtDriver Offline
Of course, once you remove the steps, you've got NOTHING between your rocker panels and granite.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: Side step removal [Re: DirtDriver] #834055 09/05/07 12:31 PM
StockRaider Offline
That gives him the ability to do what the other Gen3 guys are doing and developing rock sliders for it. I gotta say, this is really cool seeing Gen3 guys proving the Gen3 isn't a car with big tires. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Side step removal [Re: stony-man] #834056 09/05/07 01:28 PM
Mine are still on the LWB, just a little mangled. For those without sliders, we call the steps "buffer zones." <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6427 MB (Peak: 0.7666 MB) Data Comp: Off Server Time: 2026-11-18 11:54:20 UTC
