Torque Converter
#834194
09/05/07 02:30 PM
Having a problem with my wife's '99 Wrangler tranny. It's slipping when I put it into drive from a dead stop. It as got to the point where it slips going down the road now and also sometimes when I back out of the driveway. I'm looking at replacing the torque converter because that's where I think the problem lies. So I have a couple of questions regarding this. I've never replaced one so what other than the new torque converter do I need? Extra tranny fluid I'm guessing and how do I fill that converter before putting it in? I also plan on replacing the rear main seal since the tranny will be out of the way. I don't have a manual yet for this vehical so any help would be appreciated. Tips, what to look out for, warnings and so forth. Thanks in advance, <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Carl
95.5 Isuzu Rodeo 3.2 Automatic 4x4 High flow cat. Dynomax muffler Calmini high flow intake Independent 4x 3" Body Lift 305/70/R16's Dunlop Mud Rover M/T's Indy 4x 3" Suspesion Lift
Re: Torque Converter
[Re: cbb1162]
#834195
09/05/07 03:55 PM
Howdy Carl Have you installed a new tranny filter? That would be my first endeavor. If the Filter has seen a few months I'd be pulling it and spending some time looking at it before installing a new one. Tranny filters sure cause a lot of tranny slipping.
Son's GF had a TOYota that was overheating... She kept adding water and the tranny fluid COOKED in the radiator. Neither he nor she mentioned it to me untill the thing QUIT on her.. I had to put 3 new filters in it before the system got clean enough to keep itself on the road.. It ran for several years after getting the fluid cleaned up. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#834196
09/05/07 04:22 PM
You know now that you mention it I have had to add water here and there to the radiator. I also remember seeing what looked like steam coming from the dip stick tube after driving it. I just thought it was because of the slipping it was getting hot. Maybe I should spend the money on a new radiator then get some filters.
[Re: cbb1162]
#834197
09/16/07 08:30 PM
Thought I would report back and let you know how things turned out. First of all thanks to Big Jim <img src="/forums/images/graemlins/cheers.gif" alt="" />, I changed the fluid and filter once and the slipping went away <img src="/forums/images/graemlins/kewl.gif" alt="" />. I still feel a little happening but nothing like what it was doing. I plan on changing them at least one more time and all should be good. Thanks again, Carl
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6006 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-06-22 03:46:48 UTCValid HTML 5 and Valid CSS
