88 square hd light grille interchange #834229 09/05/07 06:20 PM
1
1sttrooperII Offline OP
I want to put an older style grille with round sealed beams in, is this a direct fit, or are there mods that will need to be done?
thank you, anyone want to trade grilles? <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 88 square hd light grille interchange [Re: 1sttrooperII] #834230 09/05/07 11:51 PM
lttlbddy Offline
I can't tell you but I know it's been done. Try using the search feature and see if you can find some info on the swap.
Re: 88 square hd light grille interchange [Re: lttlbddy] #834231 09/06/07 01:30 AM
RobG Offline
its about as close to bolt up as you can get. the wiring harness for the headlights is a bit different.
-Rob
Re: 88 square hd light grille interchange [Re: RobG] #834232 09/06/07 11:53 AM
4xToy Offline
Yeap the parts all just bolt in (don't forget to get the round buckets for the head lights) But you will need to redo some wiring.
-Chad
Re: 88 square hd light grille interchange [Re: 4xToy] #834233 09/06/07 05:15 PM
1
thanks for all the replies, next, where's the best place to get it, and what years am I looking for?
I'm a noob!!
Re: 88 square hd light grille interchange [Re: 1sttrooperII] #834234 09/06/07 06:22 PM
4xToy Offline
Independent4x.com sells a kit. Other than that you will have to search the salvage yards or ebay. The years you want are 1984-1986.
-Chad
Re: 88 square hd light grille interchange [Re: 4xToy] #834235 09/07/07 12:18 AM
Curtis Johnson Offline
I see your located in N. Texas.
How far from Rhome are you?
I have done this swap and can show you the parts you need to get if you want to come by my shop.
Before:
It's an easy swap as swap as go.
The Wifes' 89 Mall Crawler I'm building her.
After:
The hard part is finding the parts.
Curtis
Just call me The Gadget Master!![/b]
CurtisDrew@AOL.com
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6165 MB (Peak: 0.6905 MB) Data Comp: Off Server Time: 2026-07-09 16:12:52 UTC
