in line fuel pump ??????????
#834551
09/07/07 10:36 PM
Hey i have a 88 toy 30 4x4 and i need to know what fuel psi and gph i need for an in line fuel pump and fuel cell
i read somewhere 41psi and 24gph also where can i get a fuel pump for that psi and gph everything i have found is 6 and 7 sometimes 14 psi or does it matter? thanx everyone
Re: in line fuel pump ??????????
[Re: 89toyOn35s]
#834552
09/07/07 11:22 PM
Is your motor carb or EFI?
[Re: 89toyOn35s]
#834553
09/08/07 02:15 AM
I'm guessing 30 meant 3.0 V6
[Re: Adam F]
#834554
09/08/07 03:27 AM
Well OP, assuming you have an EFI engine, you need an EFI pump. Any pump that puts out a static fuel pressure of >40 psi will do. What's wrong with using the stock pump? Unless you're adding a turbo or supercharger, it will work fine for just about any common mods. If you want to look at an aftermarket pump, check out Walbro. Their high performance pumps come in various sizes and are affordable . -Jeff
[Re: mosk]
#834555
09/08/07 03:34 AM
thanx for the site i am looking to get ride of the fuel tank under the truck and use a fire safe fuel cell for rollovers the old fuel pump i took out was not in working order from siting for 7 years 1/2 the tank was gum what can i do to get the gum out of the fuel lines and fuel injectors? + is there anything else i need to do befor trail riding with it next weekend
[Re: 89toyOn35s]
#834556
09/08/07 06:00 AM
Some have used an in-line pump from a Celica, do not know what year they are on. But they pick them up at P-N-P wrecking yards.
Get a spray can of carb cleaner, disconnect lines at both ends, and shoot it in until it comes out the other end. Let it sit for a while then blow it out with air. Repeat. You should do it on all the lines, main, return, C.C. vent line, and anything else that carries gas. There may be a few things that need to be replaced like the fuel pressure regulator, pulsation regulator. . As far as the injectors, send them out and have them cleaned and balanced.
"Serenity through Sobriety"
[Re: OOP'S]
#834557
09/08/07 07:49 PM
pulsation regulator wtf i didn't even know anything about that what does it do and were is it at on the motor ?? also can i not clean the injectors myself letting them soak in carb cleaner
[Re: 89toyOn35s]
#834558
09/10/07 07:15 PM
Toyota Section Staffer
No you cannot. It runs $16 per for clean and balance, so there is no reason to NOT send them out.
-Bill '87 4Runner w/ '96 5VZ-FE, 'Red Chili II' '97 Taco XtraCab 3RZ-FE, 'BlackBean' TLCA # 13257, Rising Sun 4x4 Club Land Use Coordinator "He who stops being better stops being good." -Oliver Cromwell
[Re: 89toyOn35s]
#834559
09/10/07 10:56 PM
pulsation regulator wtf i didn't even know anything about that what does it do and were is it at on the motor ?? also can i not clean the injectors myself letting them soak in carb cleaner You may already have a pulse regulator on the fuel rail.. I don't know the 3.0L. You just need an inline pump.. I believe the guys on pirate recommend a pump (Ford) from one of the E-series vans. Bosche, Kinsler, lots of options...
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
