Page 1 of 3 1 2 3
Starting Problem #834701 09/08/07 02:00 PM
Baldylocks Offline OP
My 90 Montero has left me stranded again. She turns over just fine but when I remove one of the spark plug wires while trying to start herà.no spark. Then I removed the short wire to the coil, still no spark. What is the resistance of the coil? And what is the input voltage to the coil and where does it come from? Are there any other checks I can do to isolate this problem?
Thanks,
Pat
1990 MonTERROR
183.07 cubic inches of worn out FURY
New ALTINATOR
And uh... new radiator hoses UPPER AND LOWER,
SAGGING COILS, dead SHOCKS
Worn 29 x something x something else STREET TIRES
GET SOME
Re: Starting Problem [Re: Baldylocks] #834702 09/08/07 02:11 PM
FrankR Offline
+12v is supplied to the coil primary winding via the key switch. Primary resistance should be .72-.88 ohms. Secondary resistance as measured between the coil + primary blade and the high voltage secondary connector should be 103-13.9k ohms (k = 1000). The blades of the primary connector are oriented like the letter "T". The positive blade is the vertical part of the letter "T".
Other suspects are the power transistor and the ECU.
Frank
Re: Starting Problem [Re: FrankR] #834703 09/08/07 03:18 PM
Very informative Sir.
Thanks
Pat
1990 MonTERROR
New ALTINATOR
GET SOME
Re: Starting Problem [Re: Baldylocks] #834704 09/12/07 09:33 PM
carbonbody Offline
It is your ECU. My 90 did the same thing last month. http://www.avproecm.com/ $150 + shipping. Will start right up and run great! Dont even think about looking at anything else. I spent two days changing everything else. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Starting Problem [Re: carbonbody] #834705 09/12/07 09:40 PM
carbonbody Offline
By the way, a simple test to see if it's your ecu is to turn the key and if your check engine light does not come on, then it's the ecu.
Re: Starting Problem [Re: carbonbody] #834706 09/13/07 02:47 PM
I got lucky carbonbody. It was the Coil. All the posting in the world doesn't help until I went out and actually tried to fix it. <img src="/forums/images/graemlins/lol.gif" alt="" /> I stil have some terrible tapping on the drivers side that doesn't go away.
Pat
1990 MonTERROR
New ALTINATOR
GET SOME
Re: Starting Problem [Re: Baldylocks] #834707 09/14/07 02:03 PM
carbonbody Offline
You sure did get lucky! I carry a spare coil & distributor now...and will carry an extra ecu if i ever find one cheap. The ticking was horrible in my '90. I could never get it go to away for good. Marvels Mystery oil helped for awhile. Finally went away after changing my engine. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Starting Problem [Re: carbonbody] #834708 09/15/07 05:03 PM
Its called piston slap...
Re: Starting Problem [Re: fasteddy] #834709 09/17/07 02:07 PM
Thanks mr fasteddy. How migh I repair said piston slap.
1990 MonTERROR
New ALTINATOR
GET SOME
Re: Starting Problem [Re: Baldylocks] #834710 09/17/07 02:41 PM
Piston slap is caused by worn or collapsed piston skirt. Rebuild.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6391 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-10 06:32:49 UTC
