Living With Adult ADD #834765 09/08/07 06:19 PM
Baldylocks Offline OP
I was doing some searching on my starting problem and came across this statement by DougB:
THIS IS WHY YOU SHOULDN'T GET CLEANING SOLVENTS IN THE IDLE AIR PASSSAGE - IT WILL EAT THE RUBBER SEAL FOR THE COOLANT VALVE AND COOLANT WILL LEAK AND BE INGESTED INTO YOUR ENGINE!
I have the 90 Montero that won't start. I have noticed that my coolant level is slowly dropping and all hoses have been replaced. It all started coming together only TOO LITTLE TOO LATE. I admit it..... I DID spray cleaning solvents into the idle air passage!!! A lot of it too. Now I have noticed a kinda steamy smoke that comes out of the tailpipe. It is like it is freezing cold outside only that I am in Louisianan at 92 degrees. I know, I know what a dumb a$$!!!. I just didnÆt know!! NOW I do.
Could it be possible that the coolant level is dropping because it is going thru my coolant valve and is boiling off into a steam when I get to operating temp, going thru my engine and causing it die when it gets warmed up because WATER DOESN'T BURN (Wow, what a run on sentence) <img src="/forums/images/graemlins/smile.gif" alt="" />
If this is truly the case, how do I fix the little rubber seal for the coolant valve? And why doest my wife care like she used to? Why didn't my father hug me as a child......Sorry, Sorry, wrong message board. Where were we?
Oh yeah, hot, wet, steamy throttle bodies!!! Yeah baby <img src="/forums/images/graemlins/scared.gif" alt="" />
I read that Sparkum tried to bypass the coolant to the throttle body. I would love some more info on how to bypass the coolant having to run thru the throttle body and what the results were.
Pat <img src="/forums/images/graemlins/baby.gif" alt="" />
1990 MonTERROR
183.07 cubic inches of worn out FURY
New ALTINATOR
And uh... new radiator hoses UPPER AND LOWER,
SAGGING COILS, dead SHOCKS
Worn 29 x something x something else STREET TIRES
GET SOME
Re: Living With Adult ADD [Re: Baldylocks] #834766 09/08/07 10:36 PM
sparkem Offline
All I did was put bolts into the hoses and clamp them. It made my idle go way up and stay there. I have the hoses back on.
Re: Living With Adult ADD [Re: sparkem] #834767 09/09/07 02:19 PM
Well, that wasn't the problem. It STILL won't start. I am leaning towards the power transistor or the ECU.
Thanks for your help Sparkum
Pat
1990 MonTERROR
New ALTINATOR
GET SOME
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5953 MB (Peak: 0.6500 MB) Data Comp: Off Server Time: 2026-06-07 03:49:28 UTC
