Anyone in Albuquerque area purchase the Timing Belt Tensioner/Compressor? #834768 09/08/07 06:27 PM
rrolsbe Offline OP
I am due to replace my timing belt on my 1996 3.4L V6 Tacoma. Since the Tensioner Compressor is fairly expensive and I'll probably only use it once, has anyone in the Albuquerque area purchased the tool? Anyone made the crank pulley tool Mark Griese refers to in his "Timing belt replacement guide"? If so please PM me maybe we can work out a deal so I can save some mula and you can recoupe some.
Thanks for you time!
Regards
Ron
1996 Toyota Tacoma XCab 4x4 3.4L
ARB Bullbar & Warn Winch
Super Spring progressive leaf springs
SuperBumper in rear 2" receiver
Moderator Marks factory Bilstein shocks/Front Coils
Albuquerque, NM
Re: Anyone in Albuquerque area purchase the Timing Belt Tensioner/Compressor? [Re: rrolsbe] #834769 09/13/07 02:37 AM
shovelhead Offline
I did mine about 3,000 miles ago and found I didn't need it. If you move the A/C compressor out of the way you can use the tensioner mounting bolts to draw the tensioner back in place. My front pulley slid right of without any puller, holding the crank while loosening the pulley bolt is a whole nother problem
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5877 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-10-21 17:31:29 UTC
