Help me find parts numbers ... #834836 09/08/07 09:50 PM
dylanb Offline OP
Well for those who don;t know I'm in the middle of putting a 4D56 (2.3 turbo diesel) into my '85 Pickup. Fairly straight forward so far, just working on electrical and other little things right now.
Supposedly, it will bolt straight in using the original Montero motor mounts and the original clutch setup ( not sure if this is the Ranger flywheel, pressure plate, etc. or the Montero one). It doesn't seem this way in my case.
Since I am doing the swap on a pickup, I have a cable clutch rather than the hydraulic setup. The ranger had a hydraulic setup, so the pressure plate and flywheel are too thick to go into my transmission. I would use the Mitsu setup I have, but the flywheel is a good bit lighter and the diesel starter won't reach to engage the starter ring. The motor mounts don't look like they will work either, although I thought they were the same between the pickup and Montero.
Long story short, I need someone with access to CAPS to help me get a lot of part numbers, since the Dodge dealer isn't being helpful and the nearest Mitsu dealer is an hour away.
I need numbers for:
-1985 Mighty Max SP with a 2.6 (VIN JA7FK44E9FP405112)
Flywheel, pressure plate, clutch disk, throwout bearing, motor mounts
-1985 Mitsubishi Mighty Max SP with 2.3 4d56 (sorry, no VIN)
Starter motor,Flywheel, pressure plate, clutch disk, throwout bearing, motor mounts
-1985 Montero (or any other 1st gen w/ 2.6, again no VIN)
Motor Mounts
Thank you so much for any help, and sorry for the insanely long post.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Help me find parts numbers ... [Re: dylanb] #834837 09/09/07 11:00 PM
G
generation_one Offline
there is a way to get the caps access for yourself. I dont recall where it was, maybe here: http://www.stealth316.com/0-frames.htm
It was too compilicated for me. You need to have some computer slills.
It sounds like you only need to rebuild the starter to fit
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Help me find parts numbers ... [Re: generation_one] #834838 09/10/07 01:25 PM
hazy_daze Offline
CAPS is available on the Outerlimits4x4 forum. Search U/N Bitsamissin.
Re: Help me find parts numbers ... [Re: dylanb] #834839 09/10/07 03:15 PM
MarkG Offline
I have a paper copy of the 1983 Dodge Import Parts manual. I'll be happy to look up the part numbers if you think the 1983 parts will work.
Re: Help me find parts numbers ... [Re: MarkG] #834840 09/10/07 08:10 PM
dylanb Offline OP
If you can look up the part numbers for the diesel that would be really great. I downloaded CAPS and was able to find all the relevant 2.6 part numbers, but could use the diesel ones to compare.
All I would need is the flywheel, clutch disk, pressure plate ("clutch cover" or something like that in CAPS), throwout bearing, motor mounts, and starter motor for the 4d55 equipped diesel. Thanks a bunch,
Dylan
Re: Help me find parts numbers ... [Re: dylanb] #834841 09/14/07 01:41 AM
MarkG Offline
Dylan
1983 Diesel Pickup Truck 4D55 Engine
Clutch Cover Assy 2WD/4WD MD802110
Clutch Disc 2WD/4WD MD710118
Clutch Release Bearing Assy 2WD/4WD MD703270
Engine Support Front Insulator 2WD/4WD MB007023
Engine Support Front Insulator 2WD/4WD MB260664
Engine Mounting Insulator 2WD MB007132
Engine Support Rear Insulator 4WD MB260670
Transfer Support Insulator 4WD MB260676
Starter Assy 2WD/4WD MD061154
The only items different between the 2WD and 4WD trucks seems to be rear engine mounts and the transfer case support.
Re: Help me find parts numbers ... [Re: MarkG] #834842 09/14/07 04:58 PM
dylanb Offline OP
Thank you, I appreciate the help!
Re: Help me find parts numbers ... [Re: dylanb] #834843 09/15/07 01:29 AM
PHIL_ Offline
You said in your original post you were putting in a 4D56... did you mean a 4D55 (2.3) or a 4D56 (2.5)? Just wondering as this can have a profound effect on what parts you use...
Re: Help me find parts numbers ... [Re: PHIL_] #834844 09/16/07 08:24 AM
dylanb Offline OP
just a typo... it's definitely the 4d55 (2.3l) from the Ford Ranger. Sorry for the mixup.
Re: Help me find parts numbers ... [Re: dylanb] #834845 09/16/07 01:48 PM
pmontero Offline
Hi Dylan,
I'm planning on using the Ford Ranger flywheel, Ford Ranger clutch and release bearing on the '87 Mitsubishi Montero 5 speed manual truck when I put the 4D55T in. From what I can tell, it looks like it will all fit and I can use the HD starter from the Ford Ranger diesel as well. I'm also using the stock montero motor mounts and swapping the motor mount brackets from the 2.6 engine to my 4D55 block. It looks like that will fit as well.
Am I missing something? It sounds like you're thinking that won't work on your pickup. Do you have the KM145 5 speed in your truck? Let me know what you've found because I sure would hate to put this thing all together and have clutch fit problems!
Thanks,
Pmontero
P.S. - you'll probably need the pilot bearing part number for the flywheel as well.
'87 Montero Diesel
'98 Porsche Boxster Electric
and more...
Greasology
NotPetroleum
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6415 MB (Peak: 0.7665 MB) Data Comp: Off Server Time: 2026-06-07 04:35:04 UTC
