Missing Oil Cooler #834873 09/09/07 02:50 AM
Y
yankee7809 Offline OP
My '95 LS is missing it's oil cooler, which was a casualty of an engine swap just before I obtained it. I have one on my old '91 RS that is a parts vehicle now.Are the oil coolers pretty much the same between Gen I and Gen II? How important to everyday use is the cooler? I'm pretty sure that the block that was swapped into my truck was different(it was a 2000 model block)in regards to some accessories.I had to rig the oil pressure sending unit to make it work again,etc.Any information and experience is appreciated!
1995 Montero LS, KYBs, Michelin 31s. 2009 Kia Borrego EX. (Wife's wheels.)
Re: Missing Oil Cooler [Re: yankee7809] #834874 09/10/07 02:05 AM
motero Offline
Some gen one two door 3.0 did not even come with one. So I would say it is not critical to have one. But if you want one you are going to have to tear into it and see what you can do.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Missing Oil Cooler [Re: motero] #834875 09/10/07 08:29 PM
torquemonster Offline
where are the lines for the oil cooler???? they they plugged off on the engine???
Re: Missing Oil Cooler [Re: torquemonster] #834876 09/11/07 04:25 AM
Y
The line fittings on the block,which is probably out of a Montero Sport are different from the original block in that regard. I also had to put an adapter on the block to hook up the proper oil pressure sending unit so the gauge would work properly again. Don't really know what the differences are since the original block isn't in the picture anymore.Going by the part numbers there must have been some changes incorporated in to the 3.0 blocks around 1999 or 2000. I figured that it might have to have an adapter like in many of the aftermarket units.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6576 MB) Data Comp: Off Server Time: 2026-06-17 03:40:05 UTC
