Re: engine/tranny install
[Re: MAC]
#834893
09/13/07 04:51 AM
[Re: MAC]
#834894
09/13/07 06:39 AM
I set the output from the transfer on a floor jack, dollie, or the like and remove the crossmember. Start pulling and then separate on the ground That's what I meant Th Danny
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#834895
09/14/07 03:42 AM
Thanks. I assume when chaining to the two engine pull hooks all the weight is on the rear hook with the tranny/xfer attached. Does this work out ok? Would it help to put a strap or chain around the front of thr tranny also? (if it can be done). I'm just about ready to do it...
[Re: MAC]
#834896
09/14/07 03:48 AM
Just angle the chain so it is towards the back. When the tcase is about to clear the rad support, I lift it up and over. Works better with two people, one can do it Make sure the hoist rolls easily, spray the wheels with lube. Makes for a better job. Danny
[Re: toyrunner]
#834897
10/02/07 01:30 PM
ready to pull. seems all the weight will be on the one rear lifting hook... think it would help to install another lifting hook say, in the threaded hole for the starter to get a little more support? or am i worrying too much here?
[Re: MAC]
#834898
10/02/07 02:12 PM
just pull it youll be fine <img src="/forums/images/graemlins/kewl.gif" alt="" />
toyotas look good with body damage
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.008s) Memory: 0.6130 MB (Peak: 0.6993 MB) Data Comp: Off Server Time: 2026-07-13 23:03:18 UTCValid HTML 5 and Valid CSS
