ScanGauge 2 - anybody wanna share readings? #834933 09/09/07 01:51 PM
A
Alluvial_Plains Offline OP
I've had my ScanGauge 2 hooked up to my 1995 T100 SR5 auto/3.4l for a week now, and was curious how my readings compare to other T100s (particularly the TPS reading as I messed with the "Do not mess with this screw" screw awhile back).
Here goes:
TPS range 11 (idle) / 73 (full throttle)
RPM ~540 (idle, air off) / ~646 (idle, air on)
Voltage 13.4 - 13.7
Water Temp 190 (normal driving) / 199 (briefly during rush hour w/air on)
Fuel Rate 0.4GPH at idle (air off)
MPG 25.6 (best sustained) / ~4 (accelerating uphill while towing)
Man who fly airplane upside-down bound to have crack up.
Re: ScanGauge 2 - anybody wanna share readings? [Re: Alluvial_Plains] #834934 09/10/07 03:52 PM
ErikB Offline
Toyota Moderator
Not yet, but will be ordering one here shortly...
http://home.4x4wire.com/erik
Re: ScanGauge 2 - anybody wanna share readings? [Re: Alluvial_Plains] #834935 09/11/07 08:55 PM
E
eleet Offline
I have logged several runs with pcmscan. I think my TPS absolute varied between ~15 and ~77. I never saw 80. This is normal per the FSM.
My temps read out in proper degrees, but generally stayed at 88-89 C on my logged runs.
97 T100 4x4
97 328i
95 540i restoration project
Re: ScanGauge 2 - anybody wanna share readings? [Re: Alluvial_Plains] #834936 09/11/07 09:43 PM
W
Whizkidder Offline
Voltage 13.4 - 13.7
2001 Taco Double Cab 4x4 w/TRD S/C & TRD 7th Inj:
TPS: 8-76
RPM: ~650/800
Voltage: ~13.8 (unless at idle with lights, fan, etc. all on, then down to ~ 12.5)
WT: 173-187
GPH: 0.4
MPG: ~26 (sustained flat ground) / 3 (WFO)
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6002 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-07-17 02:25:04 UTC
