gearing up time its about time #835086 09/10/07 04:26 AM
cbrazor Offline OP
ok im gonna do it finely ok i got a92yj 354gears im running 34 inch tires which gears should i run <img src="/forums/images/graemlins/patriot.gif" alt="" />
92 jeep yj re 4 inch lift revolver shackels front and rear 36 inch shocks in front 27 inch in rear 34 swampers ltb 2inch wheel spacers
Re: gearing up time its about time [Re: cbrazor] #835087 09/10/07 05:02 AM
BobRowe Offline
You didn't mention what kind of transmission you have.
If high gear in your transmission is 1:1, then I'd recommend 4.10:1 gears if you do most of your ddriving on the street, and 4.56:1 gears if you do most of your driving offroad.
If high gear in your transmission is an overdrive gear, I'd recommend 4.56:1 gears if you drive mostly on the street and 4.88:1 gears if you drive mostly offroad.
Re: gearing up time its about time [Re: BobRowe] #835088 09/10/07 06:54 AM
BigJim Offline
I can't argue much with Bob's choices... I might suggest skipping the 4:10's entirely.. Not much of a step from the 3:50's.
With them big meats you will want more rpm at hiway speeds than stock gears/tires was.
Re: gearing up time its about time [Re: BigJim] #835089 09/10/07 01:57 PM
DBL_DTY97TJ Offline
I'd agree on skipping the 4:10's. I've been running them w/33's and if I did it again I'd go to 4:56.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: gearing up time its about time [Re: DBL_DTY97TJ] #835090 09/10/07 03:18 PM
BobRowe Offline
I currently run 4.56 gears with 35" tires. My high gear (TF999) is 1:1 ratio. The reason that I suggested 4.10 gears is that my setup is too high for any long distance traveling on the freeway. At 65 mph, my engine is turning about 3000 rpm, which I consider too high for constant driving. So, if someone spends most of their Jeep time on the street (a lot of Jeep owners do), I don't think they'd be happy with 4.56 gears and 34" tires. And, as we all know, the fact that someone has 34" tires on their Jeep doesn't mean they do a lot of off-roading.
Fortunately, my CJ spends 95% of its time off-road. It gets trailered to the area where I'm going off-roading. So freeway driving is something I do very rarely, and then only for short distances.
Now, if my CJ had a manual tranny with an overdrive high gear, I'd have opted for 4.88 gears. I might have even chosen 4.88 gears if my transfer case had a 2:1 Low Range, rather than the 2.6:1 that mine does.
Re: gearing up time its about time [Re: BobRowe] #835091 09/11/07 03:32 AM
cbrazor Offline OP
i have a ax15 5 speed tranny most of my driving is off road so ill probly go 4.88 do i need to change my carrirers <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: gearing up time its about time [Re: cbrazor] #835092 09/11/07 04:07 AM
BigJim Offline
I'm pretty sure the 3:50's won't fit on the same carrier that a 4:88 will.. I'd even put some money on it.
Re: gearing up time its about time [Re: cbrazor] #835093 09/11/07 04:23 AM
BobRowe Offline
I'm not that familiar with YJs. I think you have a Dana 30 front axle, and that will probably need a different carrier for 4.88 gears. I had to get a different carrier when I went to 4.56 gears.
Re the rear diff... I haave an AMC20, and the same carrier worked for 3.08 through 4.56. But I think you probably have a Dana 35 rear axle, so you're probably going to have to get a different carrier for the rear, too.
But think of it this way... As long as you have to get different carriers, forget the carriers and take this opportunity to install lockers in both axles. Be sure to get lockers that replace the entire carrier. The two most common lockers in that catagory are the Detroit EZ Locker (an automatic locker) and the ARB Locker (a selectable pneumatic locker). Were it me, I'd put the Detroit in the rear, and put the ARB in the front. That way, you can still use 4WD on the street when it snows.
Re: gearing up time its about time [Re: BobRowe] #835094 09/11/07 04:47 AM
cbrazor Offline OP
thanks man <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />now i got a new project thanks for the help <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: gearing up time its about time [Re: cbrazor] #835095 09/11/07 03:52 PM
DBL_DTY97TJ Offline
I wouldn't shell out $$ for the detroit rear to go in a dana35. If you wheel it hard with a locker on 34's it's going to break. Go gently and it may be okay. If I were to get a locker for the 35 it would be a less expensive lunch box locker (aussie's are nice) that I could give to a buddy w/out getting heartburn when I had to replace my axle.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6346 MB (Peak: 0.7426 MB) Data Comp: Off Server Time: 2026-10-22 07:41:28 UTC
