Re: Testing pulleys [Re: Dandeman] #835134 09/17/07 01:52 AM
DanSweet Offline OP
I drove it again today and all of a sudden while idling at a red light the noise intermittently stopped?! I let it idle for an extended period of time in the driveway and the noise would subside occasionally, then come back. To me it almost seems like something is loose and rattling. I seriously doubt its any of the exterior accessories because I removed everything and made sure to tighten everything when I put it back together, but are there any parts within the intake/throttle assembly that could possible come loose and cause an obnoxious rattle? Any other internal parts that could come loose? To me now it seems like it probably isn't a major moving part of the engine since it seems to come and go at random. But I could definitely be wrong on that. Thanks for the help,
Dan
94' 22re Ex Cab 4x4...pretty much stock, 2" 4 Crawler body lift and 32 x 11.50 bfg mud terrains.
Re: Testing pulleys [Re: carter] #835135 11/01/07 12:02 AM
P
ponjovi Offline
Mike, any idea where I could find the bearings for that price? I just called the dealership and they want $177 for the pulley....
My pulley went bad on a road trip, and I'm trying to get home.
Thanks!
Bryan
Re: Testing pulleys [Re: ponjovi] #835136 11/01/07 12:57 AM
4Crawler Offline
Thanks!
Bryan
Which pulley is this? I have bearings for the A/C and power steering pulleys if you can't find anything locally. Two different sizes, just need the outer diameter of the bearing to get the correct one.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6007 MB (Peak: 0.6701 MB) Data Comp: Off Server Time: 2026-06-23 11:14:45 UTC
