Electrical Problem and Need some help #835224 09/11/07 01:05 AM
jlelbert Offline OP
We went hunting and had found one of the roads were blocked and in turning around we hit some pretty rough bumps and from that time on we lost all dash gauges and the fan and funny enough the 4 wheel dont lock in. Took it to toyota and they can not find the trouble. We replaced the fuse in side the cab and it blows the fuses every time. Could it be behind the dash??? Toyotoa never did look there...
can it be behind the dash?
single choice
Votes accepted starting: 09/10/07 05:00 AM
Re: Electrical Problem and Need some help [Re: jlelbert] #835225 09/11/07 08:49 PM
E
eleet Offline
What fuses blow?
With the wiring diagram you would be able to identify the circuits on those fuses. It shows you where the wires are mounted on the truck.
97 T100 4x4
97 328i
95 540i restoration project
Re: Electrical Problem and Need some help [Re: jlelbert] #835226 09/12/07 03:14 AM
wsquaredodie Offline
I have had bad experiences with the main plug that is on the firewall going into the interior on American products. As most manufacturers use a multi pin big plug to get stuff to the interior, could be you rocked it loose. find it and try giving it a good hard wiggle. If things get better, you now where to look.
trafdlo
Re: Electrical Problem and Need some help [Re: jlelbert] #835227 09/12/07 04:03 AM
kewlynx Offline
Those dummies don't know how to troubleshoot. Drop your skidplate and get under there and do a visual on your wiring, and your vacuum to the front diff (assuming ADD diff setup). Yeah-- WHAT FUSE? You troubleshoot downstream from there; the fuse did its job as a safety device. <img src="/forums/images/graemlins/shame.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.008s Queries: 18 (0.005s) Memory: 0.6189 MB (Peak: 0.7220 MB) Data Comp: Off Server Time: 2026-10-21 16:20:27 UTC
