Carburetor help #835553 09/12/07 04:56 PM
8
87BBdriver Offline OP
Have the original carb. on 2.6L, was wondering what options I have to increase performance....choke doesn't always open fully, sluggish idling for first few minutes of cold start....bogs down on hills rather than picking up. Any help....rebuild or aftermarket carbs??
Re: Carburetor help [Re: 87BBdriver] #835554 09/12/07 05:21 PM
Boostcreepr Offline
check ebay for the weber conversion kit, will fix all your problems but isnt real emissions legal smile
Re: Carburetor help [Re: Boostcreepr] #835555 09/12/07 05:40 PM
Boostcreepr Offline
i think you can use this one ^^ someone more familiar with different setups can verify though.
http://cgi.ebay.com/ebaymotors/Mazd...itemZ150159203833QQrdZ1QQsspagenameZWDVW
Re: Carburetor help [Re: Boostcreepr] #835556 09/12/07 06:09 PM
8
Why is this not emissions legal?? Does the install require any special knowledge or just follow the directions?
Re: Carburetor help [Re: 87BBdriver] #835557 09/12/07 09:50 PM
Pete_D Offline
The legality would depend primarily on which state you live in. In Ca. we can't do anything to alter the installed emissions on a vehicle. When I had my 2.6 I lived in a county/area that didn't require smog inspections after the initial issuance. Having my own shop and personel let me play however I liked. Now, everything has to conform and there are no CARB (Air Resources Board) approved items I can use. Some states don't care what you do. To put the Weber on some of the emissions related systems have to be changed and/or, abandoned. If you have annual or semi-annual smog inspections where they verify equipment you either have to conform or put it back to stock for every recertification process.
Is it a hard install - no - not if you have been doing your own work from time to time and are saavy. There's a huge number of people that can help on this board.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Carburetor help [Re: Pete_D] #835558 09/13/07 02:38 AM
E
EyeOnCy Offline
Just to throw in my two cents I had similar problems. Truck was hard to start and wouldn't want to stay running very well. Idle was weak, low power, etc....place claimed the carb was rebuilt but I troubleshot everything to the carb being the problem. Called up Weber and ordered up the 32/34 (I believe) and installed that about a month ago, although I haven't driven it more than 10miles since its still being finished it runs worlds better. The carb sounds a lot better! You'll find some people here that think the world of the Mikuni from PMs I got, and quite a few that don't care for the Webers, but personally I think they're 100times better. More simple design, though you do disconnect a lot of the emissions and such to install it, I'm in Iowa so it doesn't much matter here. Goodluck on the decision. If you plan on keeping the vehicle any reasonable amount of time just skip ebay (So you're not dicking around w/ used equipment or worrying about it working) and just go thru Redline Weber and order up the carb kit. You get everything exactly as you need and great directions. I've never worked on a carb before and I got it all tuned and everything! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
1989 Dodge Raider 2.6L/5spd
2004 Honda Element EX
1989 Dodge Daytona Shelby Z
1993 Toyota P/U
Re: Carburetor help [Re: EyeOnCy] #835559 09/13/07 02:27 PM
8
Thanks, for the help. I am looking into seriously. I'll post back with any questions later. I am in VA, and am not sure of the emissions laws? I know they don't usually test it at inspection time.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6130 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-06-23 15:23:59 UTC
