HELP - 2001 Kia sportage 4x4 Power Steering problem #835743 09/13/07 05:38 PM
HpyUnBday Offline OP
My power steering started going on and off 2 month ago
Las month it went all the way out
Otherwise Kia running perfectly - No check engine light
fluid ok - not leaking fluid
power steering belt in good condition
already replaced power steering pump
already replaced gear box
Anymore ideas?
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835744 09/13/07 07:10 PM
Axe Man Offline
Kia Moderator Emeritus
Gee, did the power steering belt break? There should be a small belt from the crank pulley to the power steering pump. Is it present?
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835745 09/13/07 09:36 PM
Dave Scott Offline
one of the pulleys could be seized-up, too, which would burn the belt and destoy it eventually, too.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835746 09/14/07 12:32 AM
yes power steering belt is on
yes power steering belt in good condition
How many pulleys are there?
I only see one attached to the pump.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835747 09/14/07 06:55 AM
hvac1000 Offline
Try and bleed the air out of the lines. If you loosen the fittings at the gear box you may need to get new packing.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: hvac1000] #835748 09/14/07 10:13 PM
O
oul053 Offline
is the pressure valve ok?? or are they in the pump... i dont know. is the pump working and have u had the rack checked?
01 sporty, king springs,235/75/15s,tjm nudge bar,narva blue spotties,triffa spotties,uhf,dual battery sys and a sub.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: oul053] #835749 09/16/07 09:11 AM
hvac1000 Offline
the rack checked?
No rack in a Sporty. Just old style ball and sector steering box.
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: hvac1000] #835750 09/17/07 08:27 AM
O
oul053 Offline
my bad, wasnt thinking <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835751 10/05/07 12:03 AM
Thanks for all the suggestions
It ended up being the power steering pump AGAIN.
The original pump went bad so we purchased a rebuilt/refurbished pump locally and this second pump was bad.
We purchased a third pump from eBay and it is working fine now
Re: HELP - 2001 Kia sportage 4x4 Power Steering problem [Re: HpyUnBday] #835752 10/05/07 05:17 PM
blitz Offline
well..,so much for having popeye forearms <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6271 MB (Peak: 0.7172 MB) Data Comp: Off Server Time: 2026-06-07 06:08:46 UTC
