trans case leak
#835894
09/14/07 02:05 AM
okay, so my transfer case is leaking INTO my transmission still. I replaced the seal at the back of the tranny and the front of the transfer case. Somehow the ATF is still getting into the tranny (AX15)and i am stumped as to how this is happening and what to do??? anyone?? please?? 93 YJ 5spd, 4.0, teraflex SSE thanks jay <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: trans case leak
[Re: jdawg13]
#835895
09/14/07 02:42 AM
Did you seperate the tranny from the transfercase and replace the seal THERE? That is the seal that needs attention. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trans case leak
[Re: BigJim]
#835896
09/14/07 02:48 AM
thanks for replying jim. yes i did sepearate the tranny from the t-case and replaced both seals there. it is still leaking from the t-case into the tranny. when i drain the transmission fluid it is red. ugggggh!!! anything???
Re: trans case leak
[Re: jdawg13]
#835897
09/14/07 06:33 AM
Them is the seals in question.. Done correctly they should not leak. Have you checked for overfill and underfill? Perhaps you are seeing residue of the red dye.. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trans case leak
[Re: BigJim]
#835898
09/14/07 03:32 PM
the transfer case is empty, the tranny is OVER full!! a guy from another forum had asked if i had changed my transfercase, which i haven't but it made me think. when i rebuilt my tranny last year, i had a problem getting the bearing off the mainshaft so i ended up putting a mainshaft from an 87 YJ in there.... could this be the culprit???? thanks jay
Re: trans case leak
[Re: jdawg13]
#835899
09/14/07 05:21 PM
How long since the seals were replaced? Did you check weekly to see if the seals were leaking at that time? Could there be a possibility the seals were instelled BACKWARDS? (inside out) Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trans case leak
[Re: BigJim]
#835900
09/17/07 05:27 AM
seals definitely installed correct, about a month ago. Someone had suggested there is a seal/plug on the input shaft of the t-case that could be letting ATF into my trans??
Re: trans case leak
[Re: jdawg13]
#835901
09/17/07 05:22 PM
Darlin that is the seal in question here! Of course it is the INPUT shaft seal! How else would one expect fluid to change cases? Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: trans case leak
[Re: jdawg13]
#835902
09/20/07 10:55 PM
Did you ever figure out the problem with the trans fluid getting into the casing? I may possibly be having the same problem except my fluid is dripping out of a small hole on the rear of the trans housing where the transfer case bolts to the tranny. Thanks
Re: trans case leak
[Re: GwensSin]
#835903
09/26/07 12:47 PM
I still haven't had a chance to pull the t-case, But i'm fairly confident that it is this seal, as i have replaced all of the others so far. It does make sense... thanks jay
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6311 MB (Peak: 0.7186 MB) Data Comp: Off Server Time: 2026-06-21 19:01:51 UTCValid HTML 5 and Valid CSS
