trans cooler question
#835909
09/14/07 02:36 AM
Im going to add an aux trans cooler to my truck and also keep the one in the radiator. What is the supply and return lines of the radiator trans cooler. Thanks for any input! Shawn
2002 RODEO LS 3.2 4x4 32" KUMHO MTs O.M.E. 919 PROCOMP ES9000 K&N FILTER
Re: trans cooler question
[Re: kashlak]
#835910
09/17/07 05:50 PM
I don't remember off-hand and mine isn't at work today. But you can find out by pulling the lines and sticking them in a bucket, then firing it up. That's how I found out. You're going to get messy anyway when installing the cooler. Do it while the engine is cold so any splashing tranny fluid won't be hot. It doesn't come out with crazy high pressure.
If you can get someone to fire it up for you that's even better.
[Re: HCMP]
#835911
09/17/07 10:30 PM
IIRC, its the rearward most line on the tranny.
-Rob
[Re: HCMP]
#835912
09/17/07 11:58 PM
Got home and took a look at mine. If you are looking at the lines under the alternator, there are two lines running out to the stock trany cooler. The driver side line is the outbound fluid line. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: HCMP]
#835913
09/18/07 02:17 AM
Ya, thanks for the help. I ended up just running the truck in gear for a few seconds and felt the lines, the hotter being the supply line to the stock cooler.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6038 MB (Peak: 0.6683 MB) Data Comp: Off Server Time: 2026-10-26 03:41:20 UTCValid HTML 5 and Valid CSS
