trans cooler question #835909 09/14/07 02:36 AM
kashlak Offline OP
Im going to add an aux trans cooler to my truck and also keep the one in the radiator. What is the supply and return lines of the radiator trans cooler.
Thanks for any input!
Shawn
2002 RODEO LS 3.2 4x4
32" KUMHO MTs
O.M.E. 919 PROCOMP ES9000
K&N FILTER
Re: trans cooler question [Re: kashlak] #835910 09/17/07 05:50 PM
HCMP Offline
I don't remember off-hand and mine isn't at work today. But you can find out by pulling the lines and sticking them in a bucket, then firing it up. That's how I found out. You're going to get messy anyway when installing the cooler. Do it while the engine is cold so any splashing tranny fluid won't be hot. It doesn't come out with crazy high pressure.
If you can get someone to fire it up for you that's even better.
Re: trans cooler question [Re: HCMP] #835911 09/17/07 10:30 PM
RobG Offline
IIRC, its the rearward most line on the tranny.
-Rob
Re: trans cooler question [Re: HCMP] #835912 09/17/07 11:58 PM
HCMP Offline
Got home and took a look at mine.
If you are looking at the lines under the alternator, there are two lines running out to the stock trany cooler. The driver side line is the outbound fluid line.
Re: trans cooler question [Re: HCMP] #835913 09/18/07 02:17 AM
kashlak Offline OP
Ya, thanks for the help. I ended up just running the truck in gear for a few seconds and felt the lines, the hotter being the supply line to the stock cooler.
32" KUMHO MTs
K&N FILTER
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6020 MB (Peak: 0.6665 MB) Data Comp: Off Server Time: 2026-10-26 07:55:33 UTC
